crossover steering
I bought O.R.U.'s kit. If I had it to do over again I'd piece it together (much cheeper). It doesn't steer as good as before with a 6" lift & drop down draglink, & drop down pitman arm. But going to 9" I had no other choice. It has a bump steer problem now, not serious but annoying to say the least. I don't know what can be done if anything ? Because everything is tight & the king pins are shimmed.
Pro, I don't have a rag joint in the steering shaft, just a u joint & slide, both are tight. Bottom steering column bearing is ok too. It steered real good before the lift, cross over, & new tires. The new tires seem to ride ok & I've tryed psi from 30 down to 18 no difference. Put dual shocks on too, no difference & I've always had dual dampners. Found a crack in the frame behind the steering box & welded it, no difference. Will the cross over be easier on my frame ?
One thing though, the long end tie rod bar was a little sloppy, so I shimmed it a little (I know thats asking for trouble) but it wasn't that bad & I wanted to see if it would make any difference, it didn't though & the steering box seems ok though I havent messed with it. The drag link is at 7 deg.
I just keep thinking: It steered fine before I changed the steering & tires. & now it doesn't. Any ideas ?
Bigsilver,
I built one for my 95 BJ D60. It's really tall and raises the attachment point up 8.5 inches. I mounted the track bar on top of the leaf spring pack (welded the track bar bracket to the spring retainer plate) and the truck has ZERO (read: zip, nada, nothing) bumpsteer.
A diagram of the setup and block I made is in my gallery. SIMPLE to do and I bet you'll NEVER be able to break it. The really only crappy part is taking the knuckle off to machine the top flat and the top forward angle (down to the steering arm). Speaking of strong, that's why I DIDN'T go with ORU's. They only use 3 bolts in a small triangular pattern on the top and a weld across the front to hold the arm on....doesn't look too strong.
Cody
Cody
Check out OTT they have awesome high steer arms for the Dana 60. They also sell everything you need for your cross over steering. Such as, the DOM tubing for the drag link, tie rod, heim joints, and steering arms. Not that you need to go that extravagant but they do offer really "quality" parts. They have website and are based in Canada.
Actually, the crossover is a little easier on the frame due to the better leverage but like fishy said, hydro assist is the major stress reliever.
That's weird Mark. I built my own and have no bumpsteer with a single dampener. Are your front springs a high arch? Reason I'm wondering is Pro and I both have fairly flat front springs and we don't get much side shift from the steering. If you have banana springs there's a good chance that your steering is shifting the whole axle from side to side and that you'll experience bumpsteer when they compress. IF this is the case a trac bar should fix the problem.
