Wont Restart When Warm
pickup coil in distributor
I had a similar problem. Check the spark when it doesn't start. I used an old plug and just laid it on the power steering pump. It still may show a spark but if the coil pickup is misreading...it is firing at the wrong time. I would crank and crank and then get a backfire. My coil pickup in the distributor was bad. I had a post about a week ago. Part was under $20 and install was not bad just watch the clips don't fall in the distributor. JOHN
are you running headers and do you have a fan shroud. headers will heat the starter up creating starter problem, ala my truck. the fan shroud part really wont have much to do with it, but if you let it idle awhile without one after awhile it begins to overheat a bit witch makes it not want to run right. hope it helps!
just my opinion but i have had a similar problem before. mine turned out to be the coil. apparently the winding inside had broken and when it heated up the two ends would spread apart causing it to lose power and when it cooled down they went back together(thats how it was explained to me anyways). like some of the other folks i would need to know more specifics on your problem before i could be of more help. Eddie II
Last edited by eddieburnsii; 03-08-2005 at 05:52 PM. Reason: miss spelling and missing words/letters
my 76 f-250 camper special had a 460 and it would do that. i always thought that it was because there is very little room inside that engine compartment for air flow and to make matters worse the 460 is a big motor and stays very hot. my carb would get so hot that when i shut the truck off, the gas would start to boil in the float bowls and it would boil out into the manifold, in essence flooding the truck so it was very hard to start.
but let us know what your truck is doing.
There have been several posts about this same thing and most of them seem to be specific to the 460. The most common causes are a hot starter from being so close to the exhaust manifolds/headers, timing is advanced too far, and crappy battery cables. There are other possibilities, but these seem to be the most common.
Kevin K.
Kevin K.
