Drivetrain knock/rattle
Hi everybody,
I have a 79 F-250 4x4 with a mid 80s 460 and a C6 in it and when the truck is idling it makes a pretty loud knocking noise but as soon as the RPMs are raised up off idle it goes away, it does it in park and also in gear but it ONLY does it when idling, it seems to be coming from around the torque converter, I thought the converter bolts were loose but I checked them and they are ok, The engine runs strong and has very good oil pressure so I don't think its a bottom end problem??
I have owned the truck for a few months and it has done it ever since I got it but I have not been able to track it down but it is embarrasing to be sitting at a redlight and having the thing rattling like crazy
thanks alot for any advice
to check the end play you would have to put a dial indicator on the front pully and measure the amount of end play movement of the crank shaft in the engine block, too much is usually an indication of excessive wear on the thrust bearing.
heres what I would do on the flex plate, take the torque converter nuts loose and push the converter back into the trans , it wont slide much, this will allow you to grab and try to move the flex plate, hopefuly you will notice it make noise or this could determin nothing and more than likely your going to have to pull the engine or trans its just your call , which one you`ll think will be easier.
hope this helped some
The oilpan was leaking pretty bad so I thought I would replace the gasket and then also see if I could see anything in there with it off, there was a few tiny metal shavings in the oil pan, I put them up to a magnet and they stuck to it.. shavings from the main bearings wouldn't stick to a magnet would they? If I had bad mains wouldn't it cause my oil pressure to drop alot? The truck runs great and has alot of power so that would really suck if the mains were going out, I don't feel like pulling it all apart
I had been running 10w40 so I filled it back up with 20w50 and a jug of Lucas to see if that would quite it down at all but it didn't
I guess I will just keep running it til it blows, lol
Definately a cracked flywheel. I pull the trans or engine and you will see it. With oil psi numbers like that I don't think your bearings are bad. Check with a flashlight through the hole where you tighten the torque conv bolts for any visable cracks. The fact that the Lucas and 20W50 didn't assist the noise tells me its external from the engine. Take all the belts off the front to eliminate any accessories.
Ok I will have to check that out then, another one is about $55 at autozone, I had already ran it without the accesory hooked up to make sure it wasn't that either and it really does sound to me like its coming from flexplate/torque converter area... Do I need to take off transfer case or you guys think I can unbolt tranny, take out driveshaft and just slide it all back??
thanks alot for all the help guys!
