Sell me on an idea...why should i buy an explorer instead of a truck?
Are they as tough/durable/long lasting as the bigger trucks?
Are there any other points I should consider?
Thanks for the help on an otherwise vague question!
-dk9
In terms of "toughness" which I'm interpreting as payload and towing capacity. An Explorer is going to be roughly equivalent to a 1/4 ton pickup like a Ranger. A V8 Explorer (optional '96+) may begin to approach a low end 1/2 ton pickup in terms of payload and towing capacity.
Those are some thoughts. With a little more input as to your intended use, we can give more thoughts regarding this decision.
I went with a Screw, it hauls the family, and I can use the box to haul the farming stuff without getting the inside dirty. I find that the F-150 hauls trailers better (better feel and handling) then the Explorer.
What I'm trying to say is, get what suits you the best, If both are the same, get what you want.
I need to haul one child and a wife (for now on the wife part anyway) and occasionally two dogs. I make one 50 mile round trip a week, otherwise on a regular basis its just 10-20 around town miles.
about once a month, I'd like to be able to go and get wood/firewood/drywall/flooring material or the occasional car engine or body part.
Twice yearly, I would be taking it "off road" but not for the sake of offroading, rather, for the sake of hunting. 4wd+snow+deer=stew.
Explorers with higher miles (160k-220k) around here are common, and affordable.
The Explorer is better for commuting/running errands. The F150 is better for large, bulky, or dirty cargo. The Explorer is better if you want to keep the cargo out of the rain/snow/weather or if you don't have a garage and want to leave your tools in the truck overnight. The Explorer is much nicer for longer trips.
Despite the fact that a pickup has a bed that can take a "4x8 sheet flat on the floor", you can't get a week's worth of groceries into a pickup. Unless you have a cap or crewcab, the stuff in the bed will blow away, get rained on, etc, and there isn't enough room in the cab to hold all that much besides 2 or 3 people.
The F150 will tow a larger trailer than the Explorer. But either will tow a utility trailer or small equipment trailer without a problem. In my case, the clutch and Mazda 5 speed in the Explorer limit the towing capacity more than the automatic in the F150.
The Explorer is more lightly built than the F150, and heavy-duty offroad 4x4 use will beat it up. Ground clearance is not great. But I have always been surprised at how well my Explorer does when I do try to push it in these situations, and much of the time while I am hunting, I never get off at least a somewhat improved road or trail.
You can toss a deer into the back of an Explorer without a problem. Your wife might object to blood on the carpet/bumper/liftgate/etc. Bring some garbage bags or carboard, etc with you when you go hunting. An elk will fit back there as well, but you will have to quarter it up out in the field. With a pickup, you can just drop either into the bed without concern, assuming you have some way to lift the animal up. And you can wash out the bed with a garden hose.
Neither is great on gas. The pickup is 12 to 15 MPG, the Explorer is 15 to 19 MPG.
One option to consider is an Explorer plus a small utility trailer. You can get fairly nice used trailers for $500 or so. You can tow the trailer to get your once-a-month wood/firewood/drywall/flooring/car engine/body part. The rest of the time you have a smaller vehicle, easier on gas, with a nicer interior, and generally more suitable for use as a "car". I drive my Explorer 5x as much as the pickup.
In MY opinion, you just cannot beat a PU for versatility and hauling. Main drawback (as has already been stated) is unprotected cargo in the bed. I have found that by installing a light aluminum camper shell, you can solve this problem and the shell is easily removed when large/ bulky loading is needed. The light shell is removable by 1 man (but a wife/teenager helper works even better). Just remember that the shell does NOT provide a secure storage location and is easily broken into.
All other things being equal, it is a tossup.
Dialtone
