97 radio display flashing
Old Feb 24, 2005 | 09:22 AM
propjr's Avatar
propjr
When I started my 97 Explorer this morning, the radio display came up with the correct time and then started flashing "12:00". I researched in my owner's manual and of course, there was nothing in there.
Any ideas?
Old Feb 24, 2005 | 10:28 AM
texan2004's Avatar
texan2004
Did you try resetting the time? When you hit the clock button, does it begin displaying radio stations? The display on these radios is a common problem. Do a search on radio displays and you will find a ton of information. This is a link to the last time I posted a reply to this. I get no credit for discovering the link as I found it by reading soemthing from someone else.
https://www.ford-trucks.com/forums/s...42#post2405742
Hope this provides some assistance.
Old Feb 24, 2005 | 01:07 PM
propjr's Avatar
propjr
I could not change the time setting nor could I get any stations to come in on AM or FM. The tape player would not play and the same with the cd changer.
I called a mechanic friend & he thought that the battery might be on its last legs. So he suggested that I test the battery before anything done to the radio.
Old Feb 25, 2005 | 01:48 AM
87 XLT's Avatar
87 XLT
Have you checked fuse 20 & 29 interior fuse panel?
Old Feb 25, 2005 | 08:55 AM
texan2004's Avatar
texan2004
Unless you are having a problem wiht other electrical items on the vehicle, I doubt it is the battery. That said, the battery is easy enough to eliminate as a source of your problem. If the battery checks out OK, I would look to the radio as the source of the problem. These radios are notoriously unstable and unreliable but the problem is normally results in a blank display. Aside for m the internittent blankd display problem I have on my 96 Explorer, I also had a problem a few years back where the button on the volume control would pop off. I was able to replace the volume control with the one form my daughter's 97 ranger, The radio's havve different plugs so I wasn't able to just swap out radios and had to resort to replacing components.. Come to think of it, I may be able to repair the blank display problem using that old Ranger radio as well - Hmmm? BTW, I did not take the radio from my daughter. She had replaced the stock radio with an aftermarket unit and the old ranger radio is now a spare.
Point to all of this is that the radio's are a frequent source of problems in the Explorers. For whatever reason, it does not appear to be a prbolem in the Rangers and I'm not sure why.
eazrider
Sep 24, 2013 04:00 PM
Racer944
Oct 28, 2005 07:37 AM
alancp
1983 - 2012 Ranger & B-Series
Mar 25, 2003 06:47 PM
