Need help with Axle tube!
Old Feb 1, 2005 | 11:02 AM
99PSDCREW's Avatar
99PSDCREW
Here's my problem: My truck's sway bar (in front) is only being held by the driver side bracket (to the axle tube). The right side bracket is gone with exception of the top bolt holding a little square piece of metal that's still holding onto the axle tube. The bottom part of the Axle tube (pass side) is broken off so I can't bolt on the new bracket with 2 bolts. Someone told me to have the bracket welded on. What do you suggest? Thanks for any and all help here.... not driving 'til fixed....
99PSDCREW
Old Feb 1, 2005 | 07:30 PM
therigwelder's Avatar
therigwelder
fabricate a new bracket,dont weld the old bracket together,the old bracket is fatigued and will break again."wash" the old bracket off with a torch or a 4" grinder if you can get to it,then weld the new bracket in place with 3/32 7018 rods.i am not sure if your axle tubes are 1/2 thick like the kind i have on my dually but if there close that localized heating wont affect it a bit
Old Feb 2, 2005 | 10:58 AM
99PSDCREW's Avatar
99PSDCREW
Thanx therigwelder,
I have no choice but to have the new bracket welded; the old one's just GONE. I don't believe I ever had it since I bought it 42 K miles ago. I've got some buddies offering help that do welding work on tanks and retrievers, etc so I'll be in good hands. Again thanx for replying,
99PSDCREW
GySgt USMC
Skeetshooter
Nov 17, 2005 05:32 PM
99PSDCREW
Mar 23, 2005 06:00 PM
99PSDCREW
Oct 13, 2004 12:25 PM
99PSDCREW
Sep 29, 2004 03:45 PM
99PSDCREW
May 20, 2004 06:54 PM
