Explorer axle for 46 Truck
Old Jan 26, 2005 | 10:05 PM
fivefords's Avatar
fivefords
Red face Explorer axle for 46 Truck
I have read the tech article on FTE for changing out rear axles on 48-60 F series trucks. Since the spring spacing is the same on the 46 I have this question.....Does anyone know if the 89-01 2x4 Explorers have a centered differential? My 02 4x4 Explorer has an offset rearend and others I have checked do as well. I live in Ohio where it is harder to find a 2x4 Explorer. I would be concerned with tearing up u-joints if I used an offset rearend for this application. I am trying to put my 46 together as a daily driver that is very reliable. The article goes on to say that a 56-72 F series rear axle will bolt right in but I have not been able to locate one in or near Ohio and the junkyards here do not leave older vehicles sitting around like they use to. The other issue with that would be lug spacing which will not match my new Mustang II front end. Could anyone please shed some light for me? Thanks as always, Eric
Old Jan 28, 2005 | 01:18 AM
46yblock's Avatar
46yblock
Since nobody has pitched in I will give it a try. Regarding the offset rearend tearing up u-joints: I have an 8 inch rear that is offset a bit, and don't expect u-joint problems.
The 55-72 rear will bolt right up: not sure but I don't think they will unless you grind off the original spring perches and install new. Also, I believe the traditional 9 inch Ford rear didn't start until 57. Lug spacing would be delt with by redrilling the axles.
Very few of these old trucks see any serious service, so a 9 inch rear end just isn't necessary, especially with a flathead powertrain. 8 inch rears are 40 lbs. lighter than the 9 inch, a clone of the 9 inch, and will probably outlive the motor.
Bolt circle on the 8 inch is 4.5. Isn't that the same as the mustang II?
Now that I'm out on the limb maybe someone will saw it off.
P.S. I forgot to add that my '80 Granada 8 inch rear used the same '46 drive shaft and yoke into the '46 3 speed.
Old Jan 28, 2005 | 01:33 PM
fivefords's Avatar
fivefords
Thank you 46yblock for replying. I have just replaced the flathead motor and tranny with 5.0 Ford power. I am hoping to make this truck my nice weather sales vehicle so I hope to be driving it a good bit more than I have for the last 4-5 years. I am changing rear ends simply to get more parts availability...something that we all know plagues this year of truck. Did you have any spacing concerns width-wise with your Granada rear? That is the biggest concern that I would have. I appreciate your help and knowledge.
Old Jan 28, 2005 | 11:38 PM
51ford fan's Avatar
51ford fan
I'm suprised there hasen't been more talk on these forums about putting the Explorer 4X4, or a full time 4 wheel drive setup under these trucks. I have been kicking it around for my 51 F1 tring to decide which way I want to go.
Old Jan 28, 2005 | 11:54 PM
46yblock's Avatar
46yblock
fivefords, my motor is a 305 ci Y-block. The 8 inch rear did present a bit of a problem on the width. If I recall correctly, it measured 5 inches shorter than the stock '46, but I am not absolutely sure about that. I do remember I was doing a lot of measuring and became concerned with tires interfering with the bed. Ended up with a 15 X 8 inch rear wheel with 2 1/8 inch backspace to compensate for the axle. I am pretty sure wheel adapters are available if you wanted a custom wheel that did not come in that backspace.
One thing to keep in mind is that if you do decide on an 8 inch rear and find a donor car to take it out of, it will probably have a 2.79 or 3.00 ratio. You would want to pick up a new ring and pinion with at least a 3.25 ratio.
Old Jan 29, 2005 | 12:29 AM
51ford fan's Avatar
51ford fan
Look at some of the earlier Explorers in the early 90s I think their rearends were centered. Also, look at Bonusbuilt.com or 48 f1.com for some other donor car options.
Old Jan 29, 2005 | 04:03 PM
46achers's Avatar
46achers
67 thru 72 Ford truck 1/2 ton rear ends ARE a bolt-in the the 42-47 Ford trucks, also the 48 and up truck, they are 9". This is a quick easy fix, should be able to find these rears complete. I have used these rears for years now in my 46 & 47 truck.
Old Mar 15, 2005 | 06:46 PM
KennethKvittum's Avatar
KennethKvittum
fivefords could you bring me up to speed on the 5.0 in your 46, i want to do a 5.0 with C4 auto in my 47
Old Mar 15, 2005 | 09:59 PM
fivefords's Avatar
fivefords
Kenneth, I can tell you that I cheated and used a street rod shop to install my new Heidts IFS and they boxed the frame rails and welded in motor and tranny mounts for me. Unfortunately, I have not welded before and decided this did not seem like a good starter project. I am going to do a little clean-up welding on the firewall and dash. For anyone else interested I found a '68 F100 9" rear that was truly a bolt in easy fix. If you can tell me what specific measurements you need I will be glad to get them for you as the motor is currently out awaiting the firewall to be finished.
Old Mar 15, 2005 | 10:43 PM
tip49's Avatar
tip49
2000 Explorer diff
I used a 3:73 from 2000 Explorer in my 50 F1. Width about and inch outboard on each rear wheel but hope to compensate with back spacing of wheels.
Diff casing is 3" right of centre, but I don't anticipate any U-joint problems as my engine is 1 1/2" right of centre and tailshaft and pinion flange are parallel
Tom
Old Mar 15, 2005 | 11:21 PM
KennethKvittum
things like the center of the motor stands and how high or low is the bottom edge of the block
CharlieLed
Sep 22, 2006 09:59 PM
joe hoffman
Apr 7, 2006 02:47 PM
bolinb
Ohio Chapter
46
Oct 29, 2003 07:12 AM
Eric Payne
Sep 25, 1999 07:25 AM
