97 AWD Front end noise sounds like rubber/rubber
Old Jan 22, 2005 | 10:24 PM
jlouki01's Avatar
jlouki01
97 explorer getting a ton of front end noise. Sound like a rubber to rubber sound.. It when I steer and when I hit a bump. Very audible outside the truck.. scares small children and animals. Its very loud:-)
Anyone have sim experiance?
Old Jan 27, 2005 | 11:29 AM
kozar's Avatar
kozar
Yes! Sounds exactly like the problem with my '99 explorer. Started about a week ago. At first blamed it on the cold weather, but it continues all the time, steering and over bumps, etc. Seems to originate from pass. side front end, but can't pinpoint any better than that. Jacked up front, pulled pass. front wheel, nothing visual out of the ordinary. Removed shock, no effect. Sprayed rubber bushings w/silicone, no real change in noise. Very annoying sound, much like a rusty worn out bedspring! The noise is similar during steering, which has me concerned Any input appreciated!
Mike
Old Jan 28, 2005 | 08:11 AM
jlouki01's Avatar
jlouki01
From what I hear its a power steering rack bushing.
Old Jan 28, 2005 | 12:14 PM
dan8052's Avatar
dan8052
If its the same noise I had two years ago on my 96 Explorer you might want to check the lower ball joint on the passenger side. I've read this is the most common ball joint to go bad. My was split wide open and the noise started this time of year (Winter). Ford sells the part for $23 bucks and Auto Zone will rent you the press for free. It took me about 4-5 hrs. to do the job. Good Luck, Danny
Old Jan 28, 2005 | 02:54 PM
Jimmyk's Avatar
Jimmyk
I also had a similar noise in two Explorers, a 97 & 98. In both cases it was the inner tie rod. I removed the clamp from the boot and injected a silicone lubricant into the boot and replaced the clamp. The noise went away.
Old Feb 1, 2005 | 07:51 AM
kozar's Avatar
kozar
Thanks for the ideas and suggestions! I'll be checking into all of them soon.
Old Feb 3, 2005 | 06:56 AM
kozar's Avatar
kozar
As a short update, I tried Jimmyk's suggestion first, being the easiest and basically a no cost fix. All I can say is,
You Da Man!
I did sub white lithium grease for the silicone lube, and it worked great. Thanks again for the tip!
Suprawill1
Escape & Escape Hybrid
Oct 14, 2014 12:57 PM
JGFreeh
1997 - 2003 F150
Oct 13, 2010 10:10 AM
dcaprio
May 28, 2009 12:32 AM
richartdana44
Jan 16, 2006 07:47 PM
aplustechnician
Oct 17, 2005 06:06 PM
