Clicking noice when heater is on
Old Nov 24, 2004 | 12:25 PM
grease monkey's Avatar
grease monkey
I wanted to know if this is normal for the rangers when I turn on and off the heater a few minutes afterwards it will make a clicking noice. I dont know if it is the core or blower. I dont have any leaks in the cab so I dont know if it is normal for that thing to click or not.
Old Nov 24, 2004 | 12:38 PM
grease monkey
I wanted to know if it is that blend door flaping around is what I am hearing??
Old Nov 24, 2004 | 05:28 PM
Ken00's Avatar
Ken00
You might hear some of the doors move as the vacuum bleeds off, the blend door on mine is electric so you won't hear that, not sure what year you have.
Old Nov 24, 2004 | 05:56 PM
grease monkey
I have a 97 ranger
Old Nov 24, 2004 | 06:38 PM
WesGrimes's Avatar
WesGrimes
Mine started making that noise, and two weeks latter I was stuck on heat only. It was the blend door. It was the sound of the thing striping the plastic on the blend door. If it is the blend door, it will only be doing this when you change the temperature setting.
Old Nov 24, 2004 | 09:17 PM
wresleu's Avatar
wresleu
Are you sure it's not just the compressor kicking on and off?
Old Nov 24, 2004 | 10:03 PM
irazu's Avatar
irazu
Mine is doing it too. What is the fix?
Old Nov 26, 2004 | 11:18 AM
WesGrimes's Avatar
WesGrimes
Blend Door Fix
You can find the instruction on the blend door fix at
http://home.earthlink.net/~kandc1/fo...nddoorfix.html
It worked like a charm on mine, but I was not able to see anything with the mirror that is suggested in the list. I had to kind of feel it out blindly... Took me two times but I got it, and saved $1000...
