Fuel Milage HELP!!!!
Thanks!
Places to look to recover some lost MPG are: plugs, wires, cap, rotor, PCV, coil, filters, cleaning all the sensors.... MAF, IAC, EGR, o2 (usually just replace). I found ALOT of junk in my intake track. IE - TB, EGR, entire manifold. The difference in MPG and performance was night and day after I cleaned this all out. My truck has a 2 part manifold and I didn't un-bolt the lower manifold but I sprayed alot of cleaner down it to just burn off during start-up. All this cleaning and parts replacement resulted in more than a 7+ MPG gain.
Other things you might not think of looking to gain MPG is changing the fluid in the trans, and the differentials.
Which isn't outrageously low for the 3.0L, if most of your driving is in town, if it's a highway figure, then that can be improved upon IMHO.
Is your's a manual or auto tranny????
Have you modified the drive train any, like changing the rear end ratio, or using different size than stock tires, like wider or larger or smaller diameter???
If you live in cold country, then a synthetic crank case & running gear lube will likely help.
Will they pay for themselves, is another question, depending on how much you pay for them & if you can do the changes yourself.
If you live where fuel & lubricant prices are high & do the fluid changes yourself, then the payback time will be quicker.
In my own case, just changing the crankcase lube to a synthetic has given me 1.8-2.2 more summer highway mpg's, don't know about winter yet.
It didn't seem to make a noticeable summer city driving, mpg difference though, again I don't yet know about the city, winter mpg.
I like Wraith's clean er up suggestions though, that and a switch to all synthetic lubes, along with driving style changes will likely yield positive results for you IMHO.
Also do some MPG tests, or in your case Km/Liter consumpion tests with different fuels. Try, say, 5 tanks of each brand of fuel available in your area, to see which give you the best distance traveled per unit of fuel consumed & the best driveablity.
You may discover, the least costly fuel per liter, may not turn out to be the best deal overall.
Even if the cost's even out, with the more costly fuel, if it's giving you better Km/L & better driveability, then your putting fewer deposits into the engine & lubricating oil, both a big plus, over time!!!!
