Is this MPG Normal?
Is this MPG Normal?
Recently purchased '89 F250 SC 4wd 7.3L Diesel 3 speed auto. I'm getting between 11 & 12MPG city no load. Does this seem normal? I've seen the thread here that lists mileage from about 10 to 20MPG, so this seems a bit low to me, but again maybe not since it's a 4WD, etc and no overdrive. Becaomes a fairly serious question because the damned fuel guages are unreliable like every ford built in 89.
While I'm at it, is this 3 speed tranny what you tekkies are calling a C6?
Thanks.
Thanks.
The 3 speed auto is a C 6 that has a direst drive high gear.
To get good mileage on a direct drive transmission you need to keep your speed down to 50 or 60 MPH and take off from stops slowly.
I have a direct drive 4 speed 4x4 with 3.55 gears and a 70 MPH trip gets me about 10.5 MPG.
Same trip at 55 gets me about 13 MPG.
Also with all the stuff on my truck it weighs 7,860 pounds without me in it, so I am a lot heavier than most.
Thanks for the info
Well I Guess I'll try slowing down a bit. I do have the 3.55 rear end, and I have tried towing my Coleman Popup trailer (about 2500#). The trailer seems to make no difference in the fuel mileage. I guess the F250 doesn't know it's there.
I do live in hilly/mountainous terrain, and can't go anywhere but the 7-11 without either going up or down hill, so that probably has something to do with it alos.
Thanks.
Thanks.
I have a 94 F250 4x4 supercab long bed with a IDI TD, E40D, 4.10 gears 235/85/16 tires at 80psi. The truck had 122k miles at the start of the trip and a bit over 123k at the end. I drove it back from FL and tested the mileage. Here is what I got...the truck was basically empty...one motorcycle in the bed and pulling a jetski on a trailer.
Cruise Controll set at 70mph (about 2250rpm) --> 13mpg
Cruise Controll set at 60mph (about 2000rpm) --> 16.5mpg
Cruise Controll set at 55mph (about 1800rpm) --> 21.3mpg
All of the above figures are indicated (as opposed to GPS confirmed etc) and were obtained in very similar moderately hilly conditions on the same day and were tested for more than 100 miles.
