'88 F250 fuel tank valve??
Old 11-26-2001, 07:03 PM
Supercab's Avatar
Supercab
Supercab is offline
On my Brother-in-laws '88 F250, w/7.3 the fuel tank valve is apparently stuck or something, he can have the rear tank completely empty, and the front tank full, run off the front tank, fuel will be pushed or pumped into the rear tank until it comes out of the filler hose (cap) is there anything that can be done with this valve or must it be replaced? I've got it here on my desk, part#E7TB-9F271-AA, Ford wants $150.00 for this valve, and we are told that they are not available in the aftermarket.
Any ideas, or suggestions???? Will a "gas" powered truck of same year with dual tanks have this valve??
His truck is 10 years newer than mine, plus being Diesel I'm kinda lost. Thanks!! Rick
Old 11-27-2001, 12:37 PM
powerstroker250's Avatar
powerstroker250
powerstroker250 is offline
This very same thing happened to my 89 F250. Turns out it was a bad fuel pump and bad tank collector valve. I replaced both and that cured the problem. The only difference was it was my front tank pump and not the rear but it's the same problem regardless. Hope this helps.
Les
Old 11-29-2001, 08:16 AM
rob_nc's Avatar
rob_nc
rob_nc is offline
Old 12-05-2001, 07:46 AM
curmudgeon's Avatar
curmudgeon
curmudgeon is offline
Post '88 F250 fuel tank valve??
jcwhitney.com has a selector valve made by Pollak/Stoneridge for vehicles with fuel return lines. It is claimed to prevent returning fuel to incorrect tank, and to send correct tank level signal to gauge. It is for 3/8" I.D. fuel lines and 5/16" I.D. return line. The 3-port (81ZJ2687U) is $56.95; the 6-port (81ZJ2705U) is $52.95. Don't know if it'll work, but it might be worth a look.
Old 12-06-2001, 07:06 PM
Supercab's Avatar
Supercab
Supercab is offline
Thanks for the info on the valve through JCWhitney, I bought one for my '78 a few years back, so may be we'll give this a shot. Rick
Blueriver16
1999 to 2016 Super Duty
09-07-2016 07:31 AM
Dino1191
10-20-2015 07:25 AM
Ex-ChevyOwner
10-07-2015 09:14 PM
altruego
05-17-2011 04:04 PM
ribsyj
02-14-2011 10:11 AM
Quick Reply: '88 F250 fuel tank valve??
