Shifting into reverse.
Old May 11, 2004 | 12:20 AM
Revert00's Avatar
Revert00
I posted this question a while back, but didn't get any answers, hopefully some will see this and be able to help me soon.
I have a Mazda B4000 96,Automatic, with 172,000 on it, my problem is this:
This happens more often when cold than warm, so I haven't had it happen recently. When the truck has been sitting, overnight etc, when I start it and put it into reverse, it takes a few seconds to engage, kills the engine, and the O/D light flashes at me.NO check engine light at all. If I turn the key off, and then start it again, put it in reverse, everything is fine. It never does this in drive.
Fluid levels look fine. I don't know where to go from here. Let me knwo what you guys think.
Old May 11, 2004 | 11:27 AM
Traxxis's Avatar
Traxxis
Has the fluid and filter ever been changed? It's probably not the root of your problem, but I'm sure it couldn't hurt. Perhaps the cable is loose?
Old May 11, 2004 | 07:59 PM
Ken00's Avatar
Ken00
Do you have a scanner, you might find a code.
Old May 11, 2004 | 08:09 PM
Revert00's Avatar
Revert00
I do not, but will O/D faults show up on the same scanning log?
Old May 11, 2004 | 08:32 PM
Ken00's Avatar
Ken00
They may set a code in the pCM, see if a local parts dtore will check it for codes. FYI, their scanner may not pick up all the codes.
lizzardly
Feb 27, 2015 11:17 AM
turbopop
May 23, 2007 09:38 PM
seafox
1997 - 2003 F150
Apr 15, 2007 09:07 AM
Wakeboarder141
1978 - 1996 Big Bronco
Mar 15, 2003 11:31 PM
