questions aobut my 2000 B3000
Old May 9, 2004 | 10:39 PM
jaydez's Avatar
jaydez
1. What does spark knock sound/feel like? my truck feels very underpowered even for a 3.0L. Could a knock make it underpowered?
2. I have a driveline vibration ( i think) at high RPMs in all gears. could that be the flexplate being warpped? I also get a loud squeeking/creeking when starting off in 1st gear esspecially uphill (its a manual by the way).
3. the tranny feels crunchy when shifting into all gears except 5th. it kind of feels like the tranny in the 87 F350 i used to dirve for work. I changed the tranny fluid the other day and it came out brown... very brown. clould that be a symptom of a tranny going bad? are there any additives i can put in it to make ot shift smoother?
4. what is the first milage the plugs should be changed at? and what kind should i put in it?
by the way, the truck is a 2000 B3000 cab plus 4x4 manual tranny with 44k miles on it. great truck. needs a few small things.
any other things i should know about / be warnned aobut from here on out?
Old May 10, 2004 | 06:31 AM
PSKSAM2's Avatar
PSKSAM2
2. There is a TSB out about a hooting, howling, or growling on takeoff in 1st gear. My truck had it, even after I replaced the clutch. Ford's recommended service was to replace the clutch, but even they said it wasn't a sure fix. Hasn't seemed to hurt anything on mine.
4. Plugs are usually around 30k~40k. I try to at least inspect them every 10k. This helps keep them from getting stuck in there. For the 3.0L with EDIS (electronic distributorless ignition) especially, you should be using double platinum plugs such as Autolite or Motorcraft (made by the same mfg). They worked great in my '98 B3000.
You should also think about changing the Fuel Filter (usually after 30k), an often forgotten routine maintenance item.
-Jim
Old May 10, 2004 | 07:33 AM
Rockledge's Avatar
Rockledge
1. You'd know it if you had a pinging problem.
3. Sounds more like a clutch issue than a tranny problem.
Old May 10, 2004 | 09:11 AM
jaydez's Avatar
jaydez
okay, makes sense. i thought platnum plugs are supposed to last 100k miles.
as for the tranny shifting, is there any additive for newer trannies to make ot shift smoother? i know there is stuff for older trannies tht use gear oil. but anything for the new ones?
the truck is at the mechanic right now getting some of the bugs out. I'll let everyone know how it goes.
Old May 11, 2004 | 08:00 PM
roddz170's Avatar
roddz170
my manual on the 4x4 2001 b3000 is heck to shift, especially if forced, also it shakes the stick while driving something terriable, I think it's a BAD balance problem on those tranny's.
