How heavy is the cab?
Old May 2, 2004 | 10:30 PM
ClatonK's Avatar
ClatonK
I am changing frames on a 86 F150 reg cab and was wondering how heavy the cab is. What is the best method to remove it? If I was to hoist it off, where should I attach the chains?
Thanks,
Clayton
Old May 2, 2004 | 10:35 PM
parks911's Avatar
parks911
as for actual weight I can't quote you that.
I just did the cab swap last week on a 88 F-150. I had the cab stripped down to nothing but metal. Seat, carpet, trim, & dash was removed & it took 4 of us (just to be safe) to lift it & carry it about 50 feet to my other frame.
Old May 3, 2004 | 03:35 PM
bob-63-292's Avatar
bob-63-292
A neighbor and I moved mine, but we only moved it 12 feet to a dolly I'd built. And we were hurting. Another post some time back suggested hooking the hoist to the seat mount bolts (i.e. inside the cab) using an engine crane and a balancing bar. Four eye bolts and a bunch of big washers ...
I'll be trying this approach in a couple of weeks as my rather stout neighbor just put up a for-sale sign.
Bob
Old May 4, 2004 | 05:19 PM
joners's Avatar
joners
If you want to hoist it off, best bet is to use those big straps that semi trucks use. Thats what I did for my 54, we just opened the doors, and put it around the top of the cab.
We also man handled it off the trailor onto the cab with 6 guys, it was really easy, if it were off the trailor, 4 guys could have picked it up.
Old May 4, 2004 | 08:07 PM
marc9000's Avatar
marc9000
As a wild guess, I'd say a cab weighs about 700 -800 lbs. Using a strap or chain around the roof through the door openings works well, with or without the doors closed. There are other ways depending on what you use to lift it. Like anything, just use common sense.
Old May 7, 2004 | 04:32 AM
angus's Avatar
angus
I've moved a cab by myself, but that was with almost everything stripped off it (doors, dash, seat, dash...)
Old May 7, 2004 | 11:44 PM
82F100SWB's Avatar
82F100SWB
When I swapped the cab from my 82 F100 to my F250, I took a piece of 4" box tube, put a couple ATV tires between it and the cab(through the window openings with the doors closed) and hooked it to the shop crane with a couple chains... Never actually tried lifting it myself, but, I have moved Chebby cabs before, one guy on each corner, and away you go.
Aaycapp
Car/truck Buying Advice
Oct 5, 2014 01:43 PM
6t6merc
May 1, 2012 09:28 AM
76shortbed
21
Feb 2, 2009 02:27 AM
xfordman
18
Apr 13, 2005 09:22 AM
sancochojoe
Feb 17, 2004 12:59 PM
