How did you get your cab off the frame?
that would depand on what truck U have.. When I pulled mine I Used 2 Ele Wenches bolted to the Rafter if my garage.. the cable went dow to the cab thru a pulley across the top to another pulley and then back up to a chain loop on the same rafter.. came off real easy and easy to put back when I was done..
on
I've had mine off a dozen times... by myself !
I use a nylon thick sling about 3" wide looped thru the doors and lift with my engine hoist... I have just enough lift to get it above the frame and I can roll it out sideways..... but you gotta keep a short leash on it to do it... never had a problem but keep the legs way out on the hoist or it gets all puckery, ya know ???
john
john
if you got the cab stripped and the doors off buy a 12 pack and invite three friends over you can git er done i dont think its more than 200lbs ten years ago i took mine off the first time with myself and one other person if you doing it by yourself pick one side of the cab up slide a sheet of three quarter inch plywood under it and and use it as a ramp off to the side just a thought thats what i did last time when i took mine back off last winter
I took everything out of the cab and then attached 4 Ancras( motorcycle tie-downs; cam action type) to the cab and to the overhead ceiling rafters and inched up the cab. Then rolled the frame from under it. It just took the 3 of us; me, myself and I. It's real easy. Just make sure everything is secure.
john
john
One person job. Gotta be careful putting it back on, to not scratch the cab near the front door post.
the specs said 111 inches I think.. the new one (fixed) at HF says 117, and the foldable says 103.. I have the foldable.
I did it in a garage with 8 foot ceiling.
Used a 4 inch tow strap thru the windows (doors still on).
Sam
If you want to leave the body in one place and roll out the frame, this might help...I just switched frames from my panel to my pickup for the fourth or fifth time; this was the first time not done in my driveway. Don't ask why.
Actually, the panel body is easier, since it is better balanced. I use a combo of 2 floor jacks, some long doubled up 2x4s with a few saw horses, some jackstands and assorted blocks of wood.
The pickup cab wants to fall forward, since the heavy firewall juts out forward of the front cab mounting points; so, if you don't pick it from above as mentioned in earlier posts, you have to keep the front of the cab higher than the rear a few inches or more or it will fall forward. Not for the faint of heart.
Once you get the body up a little ways you can take off the rear tires and put a floor jack or something under the rear end and push the frame forward out from the body. You might have to do a few rejackulations to clear the running board supports at the front body mount area, but maybe not.
Ron
Received 1,353 Likes
on
