filler for rust pitted frame ?
Old Apr 26, 2004 | 05:38 PM
green53's Avatar
green53
Could anyone recommend a product that I can use over epoxy primer on my sand blasted frame to fill the rust pitts ? I entend to spray epoxy over the filler to encapsulate it when I get it in good shape. What are the thoughts about using products over the final paint to stop paint chips etc. Thanks, Jeff
Old Apr 26, 2004 | 11:40 PM
Aekisu's Avatar
Aekisu
<cr>
Since the frame is exposes to the elements, I would suggest using a fiberglass based filler.
What type of product are you thinking about to protect the paint?
Old May 5, 2004 | 11:51 AM
green53's Avatar
green53
I was thinking of using a Glidden epoxy that is considered an automotive primer however, it is a semi-gloss black and my supplier sayes that large truck shops buy a lot of it for frames, underneath etc. because UV rays will fade this in time. I wondered if a rhino liner type of product might work as a top coat for the frame, underside of cab & fenders etc. as well. I don't really know what I want, so please suggest something that has worked for you in the past. I will want to drive my truck in the summer ( Canada = salt ) probably no more than 2000 mi. per year. Thanks
Old May 5, 2004 | 12:21 PM
Huntsman's Avatar
Huntsman
Zero Rust. I just purchased my first gallon and have started painting inside my doors and under the fenders etc., It looks great, easy to touch up and best of all it stops rust. You can get it in assorted colors and its reasonably priced.
Old May 7, 2004 | 12:28 AM
Aekisu's Avatar
Aekisu
<cr>
Yupe, ZR is the way to go unles you are planning on doing something fancy. Besides be an excellent product, the price is right (about $50/gallon).
Old May 7, 2004 | 01:12 PM
LBell101's Avatar
LBell101
Probably a little late. But if you want to fill the pits the best product I've found is Z-chrome Rust Defender. This a sprayable polyester product that sands much easier than plastic filler and has an unbelieveable build. Feather Fill is garbage compared to this product. Spray it, sand it with 80 grit, then finish with primers as usual.
Of course if you just want to protect the frame and don't care about the pits showing products such as Chassis Saver, POR, and Zero Rust are the best.
Larry
Jimmiej08
15
Jan 29, 2017 03:47 PM
cody919
23
Aug 28, 2015 08:13 PM
Aekisu
Paint & Bodywork
Mar 30, 2006 11:58 PM
pipercub
Paint & Bodywork
Jul 2, 2004 10:23 AM
Torque1st
Paint & Bodywork
Apr 5, 2003 09:39 PM
