Rustoleum, -any experience with using for vehicle frames etc?
Old Mar 29, 2003 | 12:34 AM
Torque1st's Avatar
Torque1st
Posting Legend
I have been looking at Rustoleum products and POR-15.
I have had good luck with Rustoleum products applied as directed in the proper application.
Has anyone used the Rustoleum 9800 urethane two part coating? This stuff costs me about $105 for 5 quarts (1 gallon + 1qt activator).
Has anyone used the Rustoleum 9100 epoxy two part coating? This stuff costs me about $115 for two gallons (1 gallon of each component).
Neither product requires a primer and can be used over bare or sound rusted metal. Both can be applied with a brush, roller, or spray gun. The 9800 urethane lists the 9100 epoxy for use as a primer for severe applications. The 9100 epoxy can be used on galvanized steel.
Is POR-15 a single part urethane coating? Most of the urethanes I have used were a two part system.
Old Apr 1, 2003 | 09:55 PM
Carlene's Avatar
Carlene
Admom
Hey Eric -
You'll have to wait on that answer until I make it back out to the shop - that is unless someone else can jump in here sooner.
Old Apr 2, 2003 | 06:39 PM
Torque1st's Avatar
Torque1st
Posting Legend
Thanks Carlene
Old Apr 5, 2003 | 09:39 PM
ricgen's Avatar
ricgen
I use the epoxy paint to seal cement walls around large oil tanks that I install. I had some left over from a job, so I used it to paint the bed of my truck.After a couple of months it started to crack all over the place.I've been scraping and painting over it ever since.As far as other Rustoleum products,I painted the frame a few years ago and it looks like I just did it.Rick 1980 F350 Ilovetobounce
johnson.jeff.a
15
Dec 30, 2016 06:47 PM
Lex2002
20
Jul 26, 2016 11:31 AM
fatfenders
50
Dec 3, 2015 07:53 PM
MikeS29
Apr 21, 2011 12:50 AM
jaye
17
Jan 23, 2009 06:00 PM
