exhaust backpressure sensor
Old Apr 19, 2004 | 06:10 PM
bigpowerstroke's Avatar
bigpowerstroke
Question exhaust backpressure sensor
Why is there an exhaust backpressure sensor and how does it help to block it off?
Old Apr 19, 2004 | 06:21 PM
Fordtech1's Avatar
Fordtech1
The Exhaust Back-Pressure sensor is a variable capacitor sensor that is supplied a 5-volt reference signal by the PCM and returns a linear analog voltage signal that indicates pressure. The Exhaust Back-Pressure sensor measures the pressure in the RH exhaust manifold. This sensor is used in conjunction with the exhaust back-pressure regulator to form a closed loop exhaust back-pressure control system.
The exhaust back-pressure is controlled by the PCM to provide more heat to the coolant for cab heating when ambient air temperature is below 7° C (45°F) and engine oil temperature is below 75°C (167°F) during low load, low speed operating conditions.
An open or short in the Exhaust Back-Pressure sensor wiring will result in a low out of range voltage at the PCM, and the PCM will disable Exhaust Back-Pressure control.
Nickderky
Oct 17, 2014 07:53 PM
ColtonMullis
17
Feb 23, 2014 01:54 AM
THEDON117
30
Oct 6, 2011 11:28 AM
krija
Oct 11, 2005 04:47 PM
powerstrokin95
15
Dec 9, 2003 06:50 PM
