2000 7.3 will not start....
Old Oct 17, 2014 | 12:47 PM
Nickderky's Avatar
Nickderky
2000 f350 7.3 6 Speed wont start or run it was running monday but had a misfire ran fine sunday night and then it stalled out on me wont start since... code said (camshaft position sensor) (exhaust backpressure sensor) and (misfire rate exceeds emissions) tried replacing the camshaft position sensor tried both the pep boys and ford brand still nothing changed the fuel filter still nothing not sure why its still not starting... anybody have any ideas oil level is right and its got a 3/4 tank of fuel oil in hpop reservoir is 1 inch below top which is normal not really sure where to go from here...fuses are all good. Just want to get this thing back up and running.
Old Oct 17, 2014 | 01:05 PM
Pikachu's Avatar
Pikachu
Did you clear the codes and have the cam sensor code come back? If you did, it could be a wiring issue. Which code was it, exactly?
Old Oct 17, 2014 | 02:18 PM
whitetmw's Avatar
whitetmw
"camshaft position sensor" Easy to test and replace. You have a few ways to determine if the sensor is functioning. One would be to watch the Tachometer when cranking, the other is to back-pin the wire and attach a DMM. Under steady cranking it should be about 7 as the meter reads only the average and not the actual as the CPM is signaling in mili-seconds.
"exhaust backpressure sensor" This "could" have been generated when the vehicle was trying to be restarted.
"misfire rate exceeds emissions" are recorded. When a number in row is exceeded, a code is generated. I have tested vehicles and pulled up the Code 6 Data and seen 15,000 and more logged. No big deal if you don't have other sysptomes.
Old Oct 17, 2014 | 03:28 PM
Bonanza35's Avatar
Bonanza35
Check really close for a shorted wire on the CPS, this has happen before. Also open the fuel drain valve and see if you have good pressure coming out the bottom. If all else fails check the fuel heater fuse on some its #30, if blown change it then unplug the fuel heater before starting.
Old Oct 17, 2014 | 07:53 PM
F350-6's Avatar
F350-6
WTS light come on and go off like normal? Tach start to bounce after cranking? Describe how it stalled out.
Ryanl1287
Oct 25, 2019 04:58 PM
jerkypants
Nov 10, 2011 06:39 PM
odjrsmitty
16
Jan 24, 2011 08:00 PM
jjeffries
Jan 24, 2010 01:05 PM
dirtmonkey11
Jan 21, 2010 10:06 AM
