Bronco II Ford Bronco II
loose steering
Old Mar 13, 2004 | 09:06 AM
natsII's Avatar
natsII
loose steering
I have a 1988 BII 4x4, 2.9, automatic. The steering feels loose. It does have a little play in the steering, but just feels too easy to steer. Is there any way of making the steering stiffer? Thanks
Old Mar 13, 2004 | 09:19 AM
mrshorty's Avatar
mrshorty
Mine had a little slop in it that turned out to be a bad ball joint. Bad tie-rod ends or anything else loose in the suspension or steering components could cause the steering to feel loose. 1st thing would be to make sure everything is tight.
Old Mar 16, 2004 | 01:29 AM
CrazyFazy's Avatar
CrazyFazy
If your steering is loose in the wheel itself, up and down, take the plastic off the column (upper and lower) and tighten the 2 bolts. Mine were about halfway backed out. Really made a big difference. Hope this was what you were talking about.
pablocruz69
May 25, 2024 06:37 PM
Sickler1
Aug 14, 2011 12:36 PM
78_f150
21
Jan 16, 2011 04:24 AM
JessieDM
Apr 4, 2010 12:39 PM
no_smoking2003
1997 - 2003 F150
Dec 31, 2004 03:57 PM
