OEM#=E7TZ4209A / Teeth= 40 ring-13 pinion/
Ratio: 3.08 , Diameter of ring 8.8"
I don't believe the 3.08 was ever offered in anything but limited slip. So, you got a winner.
If you can get back to the truck you took it off of, look on the door plate. If the axle code is H8, it's without a doubt LS. But again, the 3.08 came only in LS to my knowledge.
Well, seems everyone agrees that it's a 3:08 ratio (bad for me) but 50/50 on it being a Limited Slip. Will pull the differential tonight and let you all know the end result. But hoping that it's a Limited as Opens are worthless to me.
OK Pops, you got me there. Doesn't seem like you'd want a hihg gear like that with an LS or locker. Still doesn't help Gary, in either case. It's an open unit. All manufacturers call their trucks 2 or 4WD even with open rears and fronts. Can you call it false advertising? Don't know, it's been going on forever.
