1942 Ford Truck parts
Old Feb 4, 2004 | 01:43 AM
snowjob's Avatar
snowjob
Hello everyone, I'm in the process of buying a 1942 Truck.I'm not in possesion of it yet. My question is from 1/2 ton up are the cabs, fenders ,grille etc. the same and interchangable? What weight ratings go together? Are the years 42-46 virtually the same also? All your help is appreciated. Thanks, Greg
Old Feb 4, 2004 | 10:28 AM
46fordtruck's Avatar
46fordtruck
The 42-47 are identical. The cabs from larger trucks can be used on smaller trucks, Ford lists no different numbers for them. The bigger (1.5 ton up have different fenders, they have larger wheel openings than the 1/2 and 1 ton. Grille and hood should interchange with the bigger trucks, as well as cab metal. Suspension and steering is diffeernt from 1/2 ton, to 1 ton, and up and up.
Old Mar 7, 2004 | 05:07 PM
46 pickup's Avatar
46 pickup
there is 3 different wheel opening sizes so if you are sorcing fenders from different places be carefull.i know the 1 ton and 1/2 ton parts are the same except for wheel opening size .
Steve Christensen
1947 and Older Ford Trucks
Jun 15, 2015 03:54 AM
bernette
Apr 3, 2015 09:18 PM
DerekShiekhi
Feb 2, 2015 08:22 AM
gestatin
Mar 17, 2012 07:22 AM
SnoGo'er
18
Jun 27, 2008 08:29 AM
