Sponsored by: Auxito
4th gear grind
Old Dec 28, 2003 | 10:09 AM
true4.2's Avatar
true4.2
Angry 4th gear grind
Under hard accereration my 3 - 4 shift scratches like a mad cat! My truck only has 10, 500 miles on it and it's an '03. I am going to take it to the dealer and get them to re-fill the tranny fluid. Does anyone have any suggestions? BTW it's a 4.2 obviously.
Old Dec 28, 2003 | 02:49 PM
JeremyH's Avatar
JeremyH
Drain and fill the tranny to start.....it's the cheapest. Might be your synchro's.
Old Dec 28, 2003 | 04:33 PM
true4.2's Avatar
true4.2
I think it has to do with the clutch master cylinder. What's a synchro? I'm kinda dumb. hehe
Old Dec 28, 2003 | 09:50 PM
JeremyH's Avatar
JeremyH
Your master cylinder is what controls the brakes on your truck. Read this:
http://auto.howstuffworks.com/master-brake1.htm
As for a "synchro"....that is slang for Synchronizer. Here is a good explaination of a synchro and what it does:
http://auto.howstuffworks.com/transmission4.htm
Old Dec 30, 2003 | 02:13 AM
ghaml's Avatar
ghaml
I had the same problem with my '99 F150 4X4 Sport ext cab flair side with a 4.6 w/5 spd. I also had the same problem with my '94 Ranger 4X4 Splash ext cab with a 4.0 w/5 spd. I bought them both new. Dealers replaced the syncros in both trannies but the problems didn't go away, they said I couldn't drive. I took the last dealer for a ride in my Mitsu and he changed his mind about my ability to drive and shift. It seems the slave cylinder isn't as fast as your reflexes so the clutch never disengages fully, that coupled to the Mazda transmission and you have grinding when you shift fast. I don't think they want you to hot rod these things. If I could of ordered a Lightning with four wheel drive and an extended cab I would have.
302lx
3.8 & 4.2L V6
May 16, 2010 01:52 PM
93RangerXL4x2
Ford vs The Competition
Nov 12, 2008 11:04 AM
drtnshtr
1997 - 2003 F150
Mar 2, 2008 01:28 PM
blue67stang
1997 - 2003 F150
Jan 6, 2007 05:44 PM
Inda Bonda
3.8 & 4.2L V6
Mar 1, 2004 03:33 PM
