1990 F150 runs in park and neutral, dies in gear
Old May 24, 2026 | 04:32 PM
Canthelpmyself's Avatar
Canthelpmyself
3rd Gear
I have a 1990 f-150 XLT Lariat 302 with the E4od. The motor starts and run fine in park, shift into gear fine, but as soon as I touch the gas it dies. Will rev fine in neutral, cannot take any load. Pulled the code 99 for Electronic Pressure Control Circuit, pulled the harness back to the engine bay and checked for continuity. Tested the solenoid and had no resistance where I should so I dropped the pan and replaced the solenoid pack. Just checked codes again and still getting 99. I assumed that if the transmission was defaulting to maximum line pressure that would kill the engine much like dumping a clutch at idle on a manual transmission. Any ideas? The overdrive light is still on the dash as well.
Old May 24, 2026 | 06:54 PM
Prototypemech's Avatar
Prototypemech
Disconnect your throttle position sensor and test your truck again.
Old May 24, 2026 | 07:17 PM
Canthelpmyself
3rd Gear
Thank you, that was my next guess. I have a replacement TPS, PCM, and IACV ready to go in, I was just stumped by the solenoid replacement and still pulling the 99 code. I bought the truck from my neighbour who said it started doing this while parked on his property, he just towed it into his garage and never got around to figuring out what the problem was. I ordered the likely suspects before I found that code thinking I would just throw cheaper parts at it before going down a transmission rabbit hole. I’ll get to the TPS this week and update the results.
Old May 25, 2026 | 04:58 AM
Prototypemech
99 is an odd code to throw. Remove your ecu, open it up, and look for leaking capacitors and corroded traces on the main board. Its very common for our generation trucks to have leaking capacitors and it causes weird problems.
Old May 25, 2026 | 05:22 PM
Canthelpmyself
3rd Gear
You were 100% right on the TPS, unplugged it and it started to move. Pulled the throttle body off and replaced it and IACV while I was at it. Successfully moved the truck from my neighbours place to mine, I will be doing all the fluids and a tune up now that I have it moving. I did some research on the ECM issues and from what I felt driving it I am pretty confident it too will be overhauled. Thanks for pointing me in that direction, now to see if I can remember how to solder.
Old May 25, 2026 | 06:19 PM
Prototypemech
thats great news. Please keep us in the loop so we can all learn from you.
tpone
15
Aug 18, 2025 09:29 AM
Obs7.3Powerstroker
Feb 25, 2025 06:47 PM
Camadams
17
Jun 17, 2024 04:07 AM
Iron Port
1978 - 1996 Big Bronco
Jun 20, 2017 11:44 AM
subford
Feb 25, 2011 09:50 PM
