1990 F150 M5R2 reverse gear endplay
Old May 20, 2026 | 07:23 AM
NathanBritt's Avatar
NathanBritt
4wd Low
Just about finished with my first transmission rebuild on my M50DR2 and everything is tight and I was able to adjust preload on main shaft, but the only thing I’m concerned about is the reverse gear. Brand new reverse gear and slider, but it’s got a tiny bit of slop and when I turn the output shaft by hand it wants to pop up a tiny bit. I’m concerned about it popping out of gear in reverse, does anyone know if there’s a shim I can get to adjust that endplay? I suppose I could try and make one with some steel that’s the right thickness and a couple hole saws….
Old May 20, 2026 | 07:36 AM
NathanBritt
4wd Low
Attached video of play in gear
File Type: mov
Old May 20, 2026 | 07:42 AM
NathanBritt
4wd Low
Old May 21, 2026 | 06:46 AM
manicmechanic007's Avatar
manicmechanic007
There should be some clearance there (very little) .010" or less
That reverse gear has a caged roller bearing for it to ride on
** Maybe those are missing?
How much up and down?
If it is moving up and down vertically, maybe the roller bearings, the gear or the shaft is worn
The end play adjustments for your M5ODR2 are for the mainshaft and cluster shaft, adjusted by select fit shim washers
Google M5ODR2 end play checks and specifications and it will show you a procedure and the specs
There is a 2 piece thrust washer for the reverse gear shaft, it;s also selective fit
Old May 21, 2026 | 07:37 AM
NathanBritt
4wd Low
Hi, the cluster shaft, slider, and gear are brand new from the same supplier, roller bearings are in and look good, split thrust washer is tight and 5th gear/synchro assembly feels tight and good, and I’ve got about .022” end play in the gap circled.
I made a custom washer yesterday out of grade 80 steel metal roofing material, but I realized I made it for the wrong shaft contour and there’s really nowhere to put a thrust washer to adjust the end play. The only thing I can think of is maybe the shaft or gear is slightly out of spec
Old May 21, 2026 | 08:39 AM
manicmechanic007
How far is the gear moving up and down?
You cannot just find the right Mazda shim?
If you are sure the bearings are in there, it will most likely be okay depending on how much movement there is
You need .009- .013" clearance on that 5th-reverse shaft
The shaft clearances are critical on that 5 speed for shift quality (any trans really)
Old May 21, 2026 | 10:49 AM
NathanBritt
4wd Low
There is no clearance between the split shim and the face of the synchro assembly, but there’s .022” above the split washers in the reverse gear which is visible in that gap. So that means there’s not enough clearance on 5th? I figured it needs to be tight but smooth.
Old May 21, 2026 | 10:59 AM
NathanBritt
4wd Low
Old May 21, 2026 | 05:08 PM
manicmechanic007
You should have minimum .002 there
Spec is .002-.008
You looking at a shop manual?
I am not
Old May 22, 2026 | 07:44 AM
NathanBritt
4wd Low
Nope lol I don’t have one, I might just send it
DFAR
Feb 13, 2022 08:35 AM
Winger235
Mar 18, 2007 10:45 AM
cjbronco
1978 - 1996 Big Bronco
Jan 24, 2005 06:42 PM
Leland
Apr 8, 2002 02:42 AM
