Linkage set up and kick down for c6
Old May 18, 2026 | 09:10 AM
CliffFord71's Avatar
CliffFord71
Trailering
Have a 390’fe c6 transmission. Does a cotter pin go on kick down arm and linkage? I changed rear main and had to pull trans didn’t take a picture of linkage before I disassembled (learning experience) just need help on how the setup is so I can hook back up. Thanks a picture would help or explanation on where e clamp goes too.
Old May 18, 2026 | 11:30 AM
fe390pc's Avatar
fe390pc
Try this.
Old May 18, 2026 | 12:27 PM
1browski's Avatar
1browski
It should take the little C-clips, like 97409-s in the diagram.
Old May 18, 2026 | 12:34 PM
blue68f100's Avatar
blue68f100
Depending on year it may have one of those clips that locks in place.
Old May 19, 2026 | 05:13 AM
manicmechanic007's Avatar
manicmechanic007
Right, a little spring loaded clip on both ends on the kickdown rod itself and conventional C clips on the rest of the linkage
You should be able to get those little clips still
Same ones were used on GM products for years and years too IIRR
chris989
Sep 2, 2021 07:25 AM
Phideaux
Oct 17, 2004 02:57 PM
hstormn
1978 - 1996 Big Bronco
May 19, 2004 08:07 PM
superswamper
Aug 9, 2003 09:56 PM
