Looking for a little advice from the group that would be more knowledgeable than me on some of the repairs for my '68 f100 SB that I picked up from an original owner that had a slight mishap.
I'm still trying to figure out the uploading of picture process, but the truck was hit on the driver's front corner and along with destroying the sheet metal it appears to have "slightly" twisted the front frame member a few degrees.
I have removed all the damaged body panels (except for the cowl section) but now need to access the frame issue before deciding to move forward with the remaining repairs.
Is it even possible to adjust the frame member back into alignment?
Thanks in advance for any help or pearls of wisdom that the group may be able to provide.
Yes frames can be straightened. Without seeing any pictures it's going to be hard to give you a direction. More than likely it only bent the forward extended section in front of the main engine/suspension cross support. This effects the radiator support and everything that connects to it (finders/ grill...) . Depending on how it's bent it may be as simple as using a jack to move it back into place.
blue68f100, thanks for the input. It does appear to have only affected that forward extension section.
I was hoping to just be able to heat it up a little and gently see if it could be adjusted back close to factory. I have a couple of other parts trucks to get the replacement parts from (and to confirm measurements).
I'm not sure what I'm doing wrong to upload the pictures, it gets to 90% uploaded and then just stops for some reason, I'm sure it is operator error.
I agree that truck is hit harder than you think. Before messing with the end of the frame, you'll want to take some careful measurements on the frame and make sure it isn't bent, twisted or diamonded. It sure looks like it should be. That could take someone with a frame machine, and the talent and knowledge to use it properly, to fix it right.
If the wheel alignment is off you did bend the frame and would require a trip to a shop with a frame stretcher. Like others have said if the damage is into the cowl of the cab it took a major hit. Now the inner finders mount to the side, where the side torque can mess up that area. Doing repair in that area is not easy and very time consuming and expensive.
Might take quite a while to repair that cab and the result may be not quite acceptable
The frame can be fixed
It can all be fixed
Look for another cab and hood along with the fender if you keep it
