Leaky brake line misery
Old May 2, 2026 | 03:59 PM
Coastal68's Avatar
Coastal68
Got some damaged seats(?) on these original parts and the new brake lines won't seal. This is for a 1968 F250, 2WD with discs up front. Isn't there a differential valve/proportion valve that will replace both of these? I know I probably have the part names wrong.
Summit lists GM style proportioning valve (bottom pic) that looks like it would. Anybody have any experience with this?
Old May 2, 2026 | 04:38 PM
blue68f100's Avatar
blue68f100
When I upgraded to front disk brakes I got all of my parts off a 72 year model. I got the complete I-beam assembly, MC, prop valve and petal. So look for a later model when disk brakes were more std. I did have to make a bracket to mount it on the frame and plumb it in. It will be a single unit.
Old May 3, 2026 | 06:55 AM
manicmechanic007's Avatar
manicmechanic007
I have that same proportioning valve on my 68 Camaro and it works fine
I made the swap from front drum to disc, and still have drum rears, works great
Old May 3, 2026 | 07:15 AM
Coastal68's Avatar
Coastal68
Thanks Blue.
Old May 3, 2026 | 07:17 AM
Coastal68's Avatar
Coastal68
Thanks. I swapped in discs from a '72 and this is my first brake plumbing job.
Old May 3, 2026 | 07:21 AM
manicmechanic007
I take it you can bend and double flare pipe
Mine came with a mounting bracket for hanging it below the MC
Have fun, you'll love it
Old May 4, 2026 | 08:42 AM
Coastal68's Avatar
Coastal68
I'm learning. I bought a bending/flaring kit and had mixed results so I bought a better tool for flaring. Only way to learn is try, fail and try again, right?
Old May 4, 2026 | 09:09 AM
manicmechanic007
Right, and don't be surprised if you split some brake line learning and smashing too far etc.
I find the new China brake line to be crap and it's hard to flare (for me personally)
So, I bought an old roll of NOS Ford brake line on Ebay and now I'm set for life hopefully
I still use the precut and flared lengths from Autozone too, but have to re flare them when they split
Old May 4, 2026 | 11:59 AM
blue68f100's Avatar
blue68f100
The #1 mistake made is forgetting to put the nut on before you flare the end. I use an old flaring kit mad by Ridgid, had it for 40+ yrs. The new hyd flaring tools make it look easy,
Old May 4, 2026 | 04:09 PM
1browski's Avatar
1browski
I started with a cheesy Harbor Freight tool. That didnt go over well. I got a good tool and had to re-double flare all my brake lines.
And, Ive had to cut my double flares off to put the fitting on as well.
Old May 5, 2026 | 08:12 AM
Coastal68's Avatar
Coastal68
Been there, done that.
Old May 5, 2026 | 08:15 AM
Coastal68's Avatar
Coastal68
Which tool did you buy? I have this one and it seems to make a decent looking flare, but the also creates a bluge in the line that interferes with the fitting.
Old May 5, 2026 | 04:59 PM
1browski's Avatar
1browski
I dont remember the brand without looking at it but I found it on Amazon, I think. I like it because you dont have to do it by feel how the HF one was. I also made the flares crooked. This one, you just pull the handle back and done. Perfect flares every time. The only reason I got that was I planned on doing minimum of three trucks, my 72, 70, and my dads 66 ford trucks.
Old May 6, 2026 | 12:53 PM
Coastal68's Avatar
Coastal68
Nice! If this tool fails me mayby I'll find something like yours.
Old May 7, 2026 | 07:16 PM
WDXPW's Avatar
WDXPW
This type of flaring tool gives a very good double flair and is made to only do 3/16" line its not a do all sizes okay but one size very well.
78Custom302
Mar 10, 2021 06:53 AM
Hyser
Aerostar
Sep 5, 2019 08:15 AM
mihnen
Mar 30, 2018 10:51 AM
1972F600
May 18, 2017 08:48 PM
farmboy555
Jun 23, 2015 05:58 PM
