Brake proportioning valve
Old Mar 7, 2021 | 11:17 AM
78Custom302's Avatar
78Custom302
Hey everyone,
After a long cold winter I'm starting to pick up where I left off on my '78 F-150. I'm replacing all the brake lines and I'd like to know what I need to do with the proportioning valve? Should I remove it and clean it? If so, how do I clean it? Should I get a replacement? How do i know if its working properly?
Thanks,
Mike
Old Mar 7, 2021 | 11:27 AM
beartracks's Avatar
beartracks
It appears to be leaking. I would replace it.
Old Mar 7, 2021 | 01:23 PM
dmccorkle911's Avatar
dmccorkle911
I have two if you are interested
Old Mar 8, 2021 | 07:20 AM
78Custom302
I had just sprayed it with de-greaser before the photo-so hard to tell for sure.
Old Mar 8, 2021 | 07:21 AM
78Custom302
Sure--send me some info.
Old Mar 8, 2021 | 09:44 AM
jakeharp's Avatar
jakeharp
Definitely replace, you could have a heck of a time getting new lines to seal good on the old prop valve, my experience has been old brake parts mating with new brake parts = headache.
Old Mar 8, 2021 | 10:28 AM
speedfreak78's Avatar
speedfreak78
Was it working before? Clean it,paint it, put it back. There's not much to it internally, if you want you can pull it apart and clean everything through the big nut on the end. You can search for pictures of a disassembly, doesn't have to be that Ford part, they're pretty much all the same, basically. There's no reason a new brake line won't seat, that's ridiculous, unless it's been damaged somehow. I've never heard of a prop valve failing other than when it's gunked up from never flushing the system. This is supposedly a 73-79 f250/f350 disk/drum valve cutaway i found here https://www.carolinaclassictrucks.co...d-250-350.html
Old Mar 8, 2021 | 06:24 PM
78Custom302
Cool. I think I'm going to try that. Thanks!
Old Mar 10, 2021 | 12:55 AM
thatsrealnice's Avatar
thatsrealnice
PV
I rebuilt mine. I got a rebuild kit from a place called Musclecar Research.
Old Mar 10, 2021 | 06:53 AM
headloct's Avatar
headloct
Here you go...
https://www.musclecarresearch.com/valve-kit-kh
BILLYBOB2020
May 21, 2020 09:21 PM
emeraldcoupe
Jul 12, 2018 07:46 AM
Aerotech
Large Truck
Oct 26, 2017 09:01 PM
modrob
Large Truck
13
Dec 4, 2011 06:38 PM
shameless
Oct 17, 2011 06:57 AM
