Brake line routing
Old Mar 30, 2018 | 09:06 AM
mihnen's Avatar
mihnen
Brake line routing
I'm replacing the brake lines in my truck with stainless steel pre-formed ones and everything has gone in fine except I can't figure out how the long line from the proportioning valve to the rear is supposed to get to the proportioning valve. It runs inside the frame rail from the back but when it gets to the front by the proportioning valve I can't see how it will fit through since there is something else in the frame rail there. The previous owner had copper lines and just routed it outside and over to the valve. Does anyone have a picture or know how this is supposed to be routed with stock formed lines? This is a 1979 F100 (302) 2WD with manual brakes.
Old Mar 30, 2018 | 10:51 AM
hickory1991's Avatar
hickory1991
Don't know if this will help as the picture is from my 76 f-250 4wd.
newguy399
Jun 14, 2018 06:24 AM
1972F600
May 18, 2017 08:48 PM
David LaPell
Jun 10, 2016 12:26 AM
1browski
Feb 17, 2016 11:37 PM
jtindale
Feb 27, 2012 02:00 PM
