1995 7.3PSD Crank no start, Suspect PCM
Old Apr 12, 2026 | 11:03 PM
DogfightDixon's Avatar
DogfightDixon
4wd Low
Exclamation 1995 7.3PSD Crank no start, Suspect PCM
1995 F350, CabChassis, ZF5, PCM DPC-203
Need help verifying my diagnosis before I drop money on a PCM
Problem: Original Failure happed when old man was driving truck, said it would start hard and die repeatedly some mornings till it would finally catch and stay running. He was driving it a couple days later and it started cutting out on him like somebody was turning key on and off until it sputtered and died. Had to tow pickup home, thought CPS was the issue. Replace CPS with little to no improvement, truck would occasionally start and run for a couple seconds and die, now truck wont start period. If i forgot any information i will be sure to update post.
Symptoms:
  • Low side oil pressure builds and holds while cranking, HPOP Resiviour is full
  • Watching data stream on ForScan shows ICP at 200psi MAX, usually lower.
  • IPR Duty Cycle at 50% While Cranking.
  • CPS Signal is present, shows ~200rpm on Tach while cranking
  • Good Fuel Pressure ~55-60psi (E-Fuel System)
  • No visible smoke from tailpipe
  • Cranking with valve covers off, can not see any visible leaks, no oil passing through injectors
  • Recieving 12v but no ground signal at IPR when testing with noid light
  • PCM Powering up, CEL illuminates, Sends power to IDM, Etc.
Things Done:
  • Injector O-Rings were de-laminating. Replaced All 8
  • HPOP Recently Replaced
  • IPR Recently Replaced
  • ICP Good
  • IDM Tested Good
  • New Motorcraft CPS, Harness continuity checked from PCM to CPS Pigtail, Low Resistance, No visible issues
  • UVCHs and Pigtails good, continuity checked from IDM to internal Connectors, Low Resistance, No visible issues
  • Verified Wiring from PCM to IPR, continuity good, Low Resistance, No visible issues
  • Verified PCM Ground
Summary: Does this sound like a bad PCM to you? I am out of things to try and parts to check, unless im missing something obvious. I want to be 100% positive before purchasing PCM.
Old Apr 13, 2026 | 09:35 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
200 PSI while cranking at a commanded 50% duty cycle does raise flags. It's easy to tell if it's control side problems or leakage/hydraulic part problems.
Put 12V straight to the IPR connector (limit time to under a minute though - it'll get hot). If it starts, either the IPR wiring from the PCM is bad (since you say you have 12v at the red wire when the key is on) or the IPR driver in the PCM is bad.
If it still doesn't start, you need to start testing for leaks.
Old Apr 14, 2026 | 12:56 AM
DogfightDixon
4wd Low
Update:
@cleatus12r I tried direct 12v to IPR and it didnt muster up much oil pressure, but ive also had the HPOP system open multiple times and there could be excess air in the system. However, I'm not getting any oil through injectors, even with constant 12v to IPR, its dry as a bone up top.
Pretty sure IDM isnt getting Fuel Delivery Signal from pcm, infact the pcm may not be communicating with the IDM at all. I am unable to perform a buzz test using ForScan.
I verified all wiring between PCM and IDM, which leads me to believe PCM is toast. May have a loaner known-good PCM sourced. Will install and post results!
Old Apr 14, 2026 | 07:38 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Originally Posted by DogfightDixon
Update:
The IDM has no function in building injection pressure. The IDM doesn't need power or even to be in the pickup for the high pressure oil system to build pressure while cranking. You need to find out why you have only 200 PSI. If you can acquire data from the diagnostic port, your PCM is booting at least - no guarantees on functionality though.
Old Apr 14, 2026 | 11:23 AM
DogfightDixon
4wd Low
I understand the IDM has no part in building pressure, I was just adding additional info regarding the PCM. I am unable to perform any IDM commands and, unless I'm mistaken, the PCM acts as the communication gateway to the IDM.
As far as not building HPO, I will continue to diagnose that issue tonight.
Old Apr 14, 2026 | 03:52 PM
97XLTdually's Avatar
97XLTdually
4th Gear
I feel your pain, the PCM on my 97 has kicked the bucket, honestly best way to go is pull it out and go from there, I’d either get it rebuilt or new one I don’t trust all these electronic bits much as they do go,
Old Apr 15, 2026 | 09:14 AM
DogfightDixon
4wd Low
Update:
Gave the IPR 12v direct and jumped the starter solenoid, she built 500+ psi and lit pretty quick. It was fast enough it made me flinch.
So HPOP circuit is good, its purely a control side issue now. Looking like PCM is the culprit,
I also called Ford and give them VIIN and PCM Batch Code, and they said that PCM is not the original for the vin. so that's interesting.
Old Apr 15, 2026 | 09:57 AM
knottyrope's Avatar
knottyrope
if the harness has a broken wire inside, PCM repair wont fix it
Old Apr 15, 2026 | 10:16 AM
DogfightDixon
4wd Low
@knottyrope Already check harness, visually and with multimeter.
Old Apr 15, 2026 | 01:53 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Update:
I'm not sure what a "batch code" is but it's not interesting. It doesn't matter. Any 1994.5 to 1997 49 state emissions 7.3 L with a manual transmission is going to take a DPC-203 pcm.
If you have done your due diligence with diagnostics and you do need a pcm, make sure that your IPR harness (the two wires where they connect to the IPR) has not been ruined due to fuel intrusion in the insulation. There are circuit protections in the PCM for a shorted harness but they can only take being shorted so many times before the driver burns up. You don't want to ruin another PCM if that's the case.
Old Apr 20, 2026 | 05:58 PM
Pikachu's Avatar
Pikachu
Use an incandescent test light to check for power at the IPR connector. It will probably be dim at key on, but should get fairly bright while cranking. It would be even better if you had an oscilloscope and could back probe the connector to watch voltage and duty cycle with the IPR valve still in the circuit. If there's a point of high resistance in the circuit, a multimeter will still read voltage because it puts very little load on the circuit, so that can be pretty deceptive. It's almost never the PCM.
Dirtscooter250
37
Jul 30, 2015 08:05 AM
stainlessstroker95
May 2, 2012 06:59 PM
MONAVIERONJON
Sep 8, 2011 06:55 PM
MONAVIERONJON
21
Sep 8, 2011 05:58 PM
79man
Nov 29, 2006 01:07 PM
