Fixed Warp Hood
Old Mar 31, 2026 | 05:53 PM
pltnsgt06's Avatar
pltnsgt06
Fixed Warp Hood
First, special thanks to Bob for pointing me in the right directions
I am a You Tube trained welder with Harbor Freight equipment, I have more to do but I am taking it to a body shop soon to get into primer so I stopped.
I spent $40.00 bucks at Home Depot for 3/16 treaded rods, nuts, washers, and 2” angle iron.
Instead of welding to the hood frame I used 3/16 rivets
Cut the angle iron to the width of the rib, drilled the holes and welded tabs at angles for the treaded rods.
i was able to bend the rods into the holes after threading them into rivets.
Because the rods have nuts on the back of the tabs I was able to adjust each side of the hood independently.
I may have to adjust the fenders a bit and notch the brace that is hitting the roller track on the passenger side.
Over all I brought the hood independently 3/4” on the driver side and just over 1/4” on the drivers side. The fenders in the front have a gap one one side and almost hit in the other.
Passenger side before gap
Hitting fender on driver side
Roller will not stay in track
3/16 rivet
3/16 rivet
Tool casualty
Tool casualty
Angle iron on hood, fit flush after being trimmed to length
Attached bracket. The bolts on the inside allow to adjust each side of the hood.
Threaded rod fits great. May go back and try and bend up a little more
Roller bracket hits here, may trim it to go down but over all not a bad fit
After hood a little high but not bad
After driver side, fits so easily
After passenger small gap and high
 Very tight on passenger
Big gap in drivers.
Big gap in drivers.
Small gap
Small gap
Old Mar 31, 2026 | 06:11 PM
Greg Rogers's Avatar
Greg Rogers
Cool!
pltnsgt06
Mar 31, 2026 05:32 PM
riderboy1961
May 26, 2024 07:35 PM
theastronaut
Jun 21, 2022 07:52 PM
turnrjr
Nov 24, 2019 11:22 AM
mcali2
Aug 19, 2014 10:29 PM
