Distributor stuck 240 engine
Old Mar 30, 2026 | 06:24 PM
jalls1's Avatar
jalls1
well, I screwed up trying to remove my distributor so I could replace the push rod cover gasket on my '66 F250.
On the 4 cylinder engines I'm more familiar with it's a matter of removing the locking plate and unscrewing it as its pulled upwards.
After removing the locking tab I found it very difficult to twist the distributor and was only able to pull it up just beyond the rubber o-ring. I thought it needed just a little more tug so I tried to wedge it upwards with a prybar. I was pretty shocked when i broke a tab off the distributor...
Before I try to move it back and forth with a pipe wrench, what am I missing. I looked below the distributor at what appeared to be an allen head set screw but I could not move what's in there. I'm starting to think it is merely a broken oiler port.
I've sprayed Kroil on the distributor shaft but no improvement. This is aluminum on cast iron, I hope it's not galled in place. I don't recall this kind of difficulty on my other engines.
Old Mar 30, 2026 | 06:45 PM
spurredon's Avatar
spurredon
Makes you really feel great doesn't it! Suggestions to free a stuck 292 distributor - Ford Truck Enthusiasts Forums Help removing distributor - Page 2 - Ford Truck Enthusiasts Forums Stuck Distributor Base 5.8L windsor 1989 - Page 2 - Ford Truck Enthusiasts Forums
you're not the first!
somewhere on here there is talk about using something than goes after the aluminum corrosion but I have.t found it yet.
I lied, here it is Stuck Distributor: the final "solution"... - Ford Truck Enthusiasts Forums
Old Mar 30, 2026 | 07:59 PM
rdixiemiller's Avatar
rdixiemiller
When you replace the dizzy..,
Put antiseize on the housing where it fits in the block.
When I turned wrenches in Florida in the 70’s, I ran into a lot of stuck distributors. I’ve had to heat the boss in the block with a cutting torch, then dribble diesel fuel on everything while it’s still smoking hot. I have broken my share, used a pipe wrench to crack them loose.
Work it up and down while spraying it down with the penetrating oil of your choice. It will eventually surrender.
Rod Beauvex
Aug 31, 2024 09:45 PM
Nelsonak
Aug 31, 2022 01:16 PM
NoHecks
22
Jul 19, 2021 04:41 PM
warren561
Sep 9, 2014 08:42 PM
AbandonedBronco
Jan 19, 2012 02:27 PM
