Headlight gap help.
Old Feb 25, 2026 | 06:03 PM
Green5.8's Avatar
Green5.8
5th Gear
Headlight gap help.
Recently replaced my header panel and noticed that the headlight bezels no longer sit flush like they did before. I have attached some pictures, the green truck is mine and the bezels and the red one is how it is supposed to sit. Any ideas on what might be causing this? Or how to fix it. Any help would be appreciated!
Old Feb 26, 2026 | 12:44 AM
My4Fordtrucks's Avatar
My4Fordtrucks
What is a header panel?
Old Feb 26, 2026 | 12:48 AM
Green5.8's Avatar
Green5.8
5th Gear
it is the plastic piece that goes in front of the core support and holds all of your headlights and grille.
Old Feb 26, 2026 | 04:26 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
You have to draw in on the small 10mm? nuts, to suck that gap up.
Old Feb 26, 2026 | 07:54 AM
wwhite's Avatar
wwhite
Your fender is dented, and more than likely the other metal parts are out of alignment as well.
What does your door gap look like?
Old Feb 26, 2026 | 08:30 AM
Green5.8's Avatar
Green5.8
5th Gear
door gap is perfect. I’ll take a picture of it later when I get back to my shop but everything is straight. The fender looks dented but it isn’t. Everything is straight up front.
Old Feb 26, 2026 | 08:31 AM
Green5.8's Avatar
Green5.8
5th Gear
also, didn’t have this issue until after I replaced the header panel.
Old Feb 26, 2026 | 08:34 AM
My4Fordtrucks
Thanks for clearing that up. See below…
Agree. The metal panels have to be out out of alignment.
Old Feb 26, 2026 | 03:05 PM
wwhite's Avatar
wwhite
The 'header panel' is not correct then.
Compare with the old one.
Get a factory one from the junk yard.
More than likely poor quality aftermarket parts, just read a post with your same issue, ...your not the only one.
Old Feb 28, 2026 | 10:01 PM
AuroraGirl's Avatar
AuroraGirl
11mm
scraprat
Oct 27, 2025 11:43 AM
350Recon
2023+ Super Duty
May 1, 2025 08:51 AM
AngelesCrest
Mar 20, 2018 01:38 PM
woodnthings
Ford Truck Parts for Sale
Apr 25, 2012 11:12 AM
