General Diesel Discussion
Diesel Filters -i made the mistake you don't have to
Old Feb 19, 2026 | 12:33 PM
ForBruce's Avatar
ForBruce
Ford 2020 F-25 6.7L
In my infinite wisdom, i attempted to drain the Diesel water separator, but my brain was shut that day . WHY ..because i had a FULL tank of Diesel and after draining 4 1/2 gallons ,the light bulb lit up .
I WAS SIPHONING THE TANK . never walk away from a draining water separator filter (lucky it was a 5-gal bucket) ...DAHHHHH
So the next step , after i closed the drain was to use all the Diesel till i reached only 1/4 tank.
I parked the truck in my driveway NOSE UP , (slanted driveway) and opened the 3 engine Diesel fuel filter lines first. Then went under and started the Water separator draining.
Low and behold only about 1 to 1-1/2 quarts drained and then stopped completely.
Replaced both filters and no leaks. Lesson learned
BTW..... Ford had some trouble with the FD-4625 engine filters. They did not take the engine heat very well and some leaked ...MINE INCLUDED. Lucky the leak was slow and smelly.
The latest replacement series FD-4647 is stronger and takes the heat better.
2/20/26 additional thought to ponder............. what broke the siphon effect. Was it the 1/4 tank of diesel and the driveway slant .....or was it the fact that that i broke suction by opening all 3 connections at the engine compartment diesel filter ...your thoughts ??
Old Feb 19, 2026 | 12:55 PM
49 ford ana 2 dollar bill's Avatar
lesson learned, i hope you didnt beat yourself up too badly.
myself- i drain out maybe a cup at most, but i haven't done it for some time so thanks for reminding me
Old Feb 19, 2026 | 01:37 PM
ForBruce's Avatar
ForBruce
--cup at most you are referring to only water ? .......i'm not talking about a CUP OF WATER . i mean the Diesel gas tank holding 34 gallons.
Old Feb 23, 2026 | 12:15 PM
WE3ZS's Avatar
WE3ZS
Opening the top filter connections first made the difference, but doing the job on a low tank level is still a good idea.
I like the camper quote! Hard to hit a moving target!
Old Feb 23, 2026 | 12:31 PM
ForBruce's Avatar
ForBruce
i agree with you on the top 3 connections . Robert...
Hope the Blizzard didn't hit you too hard this weekend 2/21/26
Regards (n2ffs)
Old Feb 23, 2026 | 02:12 PM
WE3ZS's Avatar
WE3ZS
Only got about 10” of the white stuff this go round, way less then the weather guessers predicted.
ks4722
May 13, 2025 12:19 PM
IowanHooligan
6.7L Power Stroke Diesel
36
Jan 2, 2023 01:26 PM
viperman86
18
Aug 28, 2018 05:20 PM
dreamdiesel01
Apr 24, 2007 08:54 PM
