Cheap e-fuel banjo adapter leaks
Old Feb 15, 2026 | 03:34 PM
mechmagcn's Avatar
mechmagcn
Hi all! As the title says, I installed a cheap eBay e-fuel kit on my 97 and can't for the life of me get the banjo fitting to seal off. Tried the soft aluminum washers that came in the kit, leaked a lot. Put the original copper washers back in after heating them till the color changed (an old trick we used often on copper seals in hydraulic repair) and have it down to a slow drip. I'm not impressed with the adapter as it just attached to the banjo, no support at all.
Suggestions on a different adapter before I go my own way and just replace the banjo with a T and hoses to the heads? Also, what size are the threads into the heads?
Old Feb 15, 2026 | 04:32 PM
Lepidopterodactyl's Avatar
Lepidopterodactyl
I'm not sure if my cheap banjo adapter leaks because I'm leaking a lot of oil. That being said, I plan on replacing the stock fuel lines at some point. As luck would have it, @NJ_Phil just went through this: https://www.ford-trucks.com/forums/1...onversion.html
Old Feb 15, 2026 | 04:52 PM
mechmagcn's Avatar
mechmagcn
Thank you! That's very similar to what I had in mind.
Old Feb 16, 2026 | 03:54 PM
mechmagcn's Avatar
mechmagcn
Realized today that the exhaust is going to have to come off of the back of the engine to change the fittings in the heads, so I ordered the banjo adapter bag from Marty's. Let's see if I can get this one to stop leaking.
Old Feb 20, 2026 | 02:25 PM
mechmagcn's Avatar
mechmagcn
I got the fittings and washers in from Marty's, the install went smoothly and so far no leaks.
Old Feb 20, 2026 | 04:34 PM
defdes's Avatar
defdes
Be very careful removing and installing those, the casting is apparently fairly thin there and prone to cracking probably more from over tightening the fittings. I did see someone on YT do it with turbo and up pipes installed, but I think he said it took him a couple of days.
Old Feb 20, 2026 | 09:56 PM
mechmagcn's Avatar
mechmagcn
The only way that I could see to remove the fitting from the left head would be either break or cut it, then use an ease-out to remove the threaded part, there's no way that the 90° elbow would clear the exhaust flange. The RH would take a contortionist to get past the downpipe..
Kirbys73F100
Feb 11, 2011 12:14 AM
fords and kenworths
Apr 5, 2009 01:24 PM
fords and kenworths
Apr 4, 2009 12:56 AM
debestuss
Jun 13, 2005 05:11 PM
