Steering column shift Tube Retainer Bolts
Old Jan 21, 2026 | 02:55 PM
68$hevellE's Avatar
68$hevellE
8th Gear
I have a 1965 Ford F100 that has been converted to PS with a 1978 Bronco Tilt Automatic Column best I can tell from Schematics and I am missing one of the shift tube retainers/bolts, see attached. I have looked everywhere looking for these little boogers and can't seem to find any like mine, see attached pic. My question is, do any of you know where I might be able to find them. I know that the F150 columns are very similar and I have searched for them also with no luck. Thanks and I appreciate the info you can give me if any.
Old Jan 22, 2026 | 04:27 AM
Crop Duster's Avatar
Crop Duster
The tilt mechanism is the same for cars, trucks and vans from the 60's up into the 1980's as far as I know all the parts are obsolete. If you can't find a column locally to mine parts from PM me, I probably have one. Make sure that the column locking lever PN- D0AZ-3B661-A replaced by E2TZ-3B661-A is in good condition if it isn't the steering wheel will slip when you put pressure on it. I have a 79 tilt in my 65 and personally I haven't found it to be very useful, and it adds a very expensive turn signal switch to the mix.
gwp36530
Aug 12, 2024 07:35 AM
krzldy1949
1997 - 2003 F150
Jan 5, 2024 12:56 PM
NashvegasMatt
Nov 28, 2017 07:38 PM
oleblu67
Sep 3, 2014 02:23 PM
ford1967
Nov 11, 2003 07:17 AM
