Sponsored by: Auxito
Shifting lever
Old Jan 4, 2024 | 11:12 AM
krzldy1949's Avatar
krzldy1949
4wd High
Shifting lever
2001 Lariat. There are three bolts that hold shifting lever on right side of steering column. Can be seen by looking up at dash from floorboard. One fell out and I can't find info on replacement. Dealer has no info on part. What can I use to tighten lever? Can I just remove one of the other bolts and find a replacement? Thanks. Sorry if this sounds stupid...
Old Jan 4, 2024 | 08:34 PM
projectSHO89's Avatar
projectSHO89
Visit a pick n pull and help yourself to a couple of them.
Old Jan 5, 2024 | 07:45 AM
manicmechanic007's Avatar
manicmechanic007
You are talking about the T30 Torx screws that hold the shift lever to the shift tube right?
These?
They are the same bolts that hold the shift tube to the column
Laying on the floorboards of trucks at the junkyard when the shift tubes are removed
You can just use metric hex head bolts as replacements.
manicmechanic007
Old Jan 5, 2024 | 12:56 PM
krzldy1949's Avatar
krzldy1949
4wd High
Thank you all!!!! That's it! I'm not close to a junkyard. Amazon has Torx Rexka T30 would that be the same? Set of 20? Sorry, kind of dumb about this.
What size metric hex bolt?
When I looked them up they came in all different sizes.
Thanks again.
henryf1
1983 - 2012 Ranger & B-Series
Dec 17, 2022 11:17 AM
75f100hsv
May 1, 2019 11:24 AM
DougieWebb
Apr 28, 2013 09:28 AM
docsimmons96
Jun 14, 2011 01:00 PM
gt40racing
Jan 11, 2011 10:06 AM
