1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Unibody value
Old Dec 28, 2025 | 09:20 AM
Yelf100's Avatar
Yelf100
4th Gear
Unibody value
Hello! I am new to the forum, is there a way to tell if its a unibody by vin number?
And also whats the value of a decent car?
regards E
My F100
My F100
ric
Old Dec 28, 2025 | 09:29 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Not from the VIN but the body code would be a 66A (Standard Cab) or 66B (Custom Cab) compared to a conventional cab truck that would be a body code 81A (Standard Cab) or 81B (Custom Cab). The problem is they didn't start putting the body code on the warranty plate until 1963. But visually your truck is definitely a Unibody.
Vin decode please? - Ford Truck Enthusiasts Forums
Old Dec 28, 2025 | 09:40 AM
Yelf100's Avatar
Yelf100
4th Gear
Thank you! Then my Ford has to be earlier than 1963 because the plate only says: model J F100
Old Dec 28, 2025 | 09:43 AM
TA455HO's Avatar
TA455HO
Lead Gopher
If you give at least part of the vin minus maybe the last 3 digits if you want to keep it private I can tell you month and year it was built. Looks to have a 1962 grille.
Old Dec 28, 2025 | 09:45 AM
Yelf100's Avatar
Yelf100
4th Gear
F10J6205
Old Dec 28, 2025 | 10:08 AM
Yelf100's Avatar
Yelf100
4th Gear
Sorry it was F10JG205
Old Dec 28, 2025 | 10:21 AM
TA455HO's Avatar
TA455HO
Lead Gopher
205,001 through 209,999 were built in August 1961 for the 1962 model year. Your F100 came with a 223 6-cylinder engine and was built at the Chicago, Illinois assembly plant. If that's a short bed, then it's fairly desirable. Appears as a Standard Cab not a Custom Cab but that's just from the lack of trim around the windshield so not 100% certain. The doors are unique to the unibody trucks - the body line down the side below the door handles is straight compared to the conventional cab trucks that have a dog leg in that same body line like in the picture below.
If no rust it could probably fetch $10,000 to the right buyer. Maybe more depending.
sternsteve12
Nov 2, 2021 06:10 PM
dcsmitty
Aug 17, 2021 05:31 PM
Beekmann
Sep 26, 2017 05:28 PM
Mike Shuey
Jul 24, 2017 12:02 PM
NRGarrott
Jun 23, 2012 09:48 AM
