2006 F-250 5R110W clunking from park into drive
Old Dec 23, 2025 | 04:09 PM
bgblktruk's Avatar
bgblktruk
Hi guys, i have an ongoing issue after a rebuild (about 9000 miles) and replacing (allegedly) the solenoids and body.
The condition is from park into drive the car will drag a bit before clunking into gear, giving it a bit of throttle seems to speed up the process. It is intermittent and happens more often than not. It does not happen in reverse and only from park into drive. No other shifting issues while driving. The buillder without discussion used liquid Molly vs dexron V.
The builder is untrustworthy and difficult to deal with. Im wondering if its worth flushing the trans and replacing the filter. Can the solenoids be tested individually?
Thanks in advance
Mike
Old Dec 23, 2025 | 09:36 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Are there any codes stored in the PCM?
Old Dec 24, 2025 | 02:05 PM
bgblktruk's Avatar
bgblktruk
No codes. I've read with both Edge and Forscan lite.
No flashing tow haul.
Old Dec 29, 2025 | 10:46 AM
bgblktruk's Avatar
bgblktruk
Update
There were bolts in the pan from the valve body. Unclear if that's the cause of the problem. The drained it and are refilling with dexron.
Fingers crossed
Old Dec 29, 2025 | 03:47 PM
Mark Kovalsky
That's the wrong fluid. It may destroy the transmission.
The 5R110W requires MERCON SP or MERCON LV.
Old Dec 29, 2025 | 03:54 PM
bgblktruk's Avatar
bgblktruk
thank you Mark, i misspoke (typed) Mercon is what they installed.
Old Dec 29, 2025 | 05:13 PM
meborder's Avatar
meborder
Which Mercon?
You can still buy bottles that say Mercon/Dexron3 on the label (valvoline being one that comes to mind). You can also buy Mercon V, but that is not Mercon SP or Mercon LV.
I think Valvoline MaxLife has been recommended before. It at least claims to be compatible with LV, SP, and V and by all reports is a pretty good fluid.
Make sure you have a compatible fluid.
Old Dec 29, 2025 | 09:35 PM
Mark Kovalsky
If it's just MERCON, they found fluid that's been sitting on a shelf for 20 years. Nobody has made MERCON since 2006. And MERCON will cause the trans to fail just as fast as DEXRON.
I'll bet if they used MERCON V, you won't make it 20 miles before the trans fails. If they used MERCON ULV, I have no data, but my guess is it won't make 1000 miles before the trans is so damaged it isn't worth rebuilding.
The answer is to use MERCON SP or MERCON LV. Period.
Old Dec 29, 2025 | 10:23 PM
meborder's Avatar
meborder
This is the Mercon I was referring to. You can still buy Mercon Spec fluid, it just isn’t certified. APQI does checks on them occasionally to see if they meet the original specifications, but they aren’t certified fluids.
you are right that Mercon fluid hasn’t been made in 2 decades, but fluids that meet the original specs have been made since ford stopped certifying them.
the real brain teaser is that valvoline max life advertises to be compatible with Mercon, V, SP, and LV but I don’t think it’s certified in any of them.
Old Dec 30, 2025 | 10:09 AM
1Butcher's Avatar
1Butcher
Yeah, 'Suitable for use in' does not mean much to me. In house testing saying it works is equally disturbing. Valvoline is not a small company so if they say it works, then maybe it does. If it does not, I bet they have way more lawyers than you do.
Old Jan 7, 2026 | 08:25 PM
bgblktruk's Avatar
bgblktruk
I followed up it was mercon LV. The truck is still lurching. There was no significant metal. Here is a picture of the pan with the bolt from the solenoid body in the bottom of the pan.
Old Mar 23, 2026 | 12:23 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I'm curious how this is going . . .
Old Mar 24, 2026 | 12:58 AM
bgblktruk's Avatar
bgblktruk
No progress still having to rev it to get it to go. Once it's driving I have no symptoms. No slipping no codes. Very frustrating to say the least.
Still looking for any help.
sedi
2004 - 2008 F150
Mar 30, 2023 02:37 PM
joepires
Modular V8 (4.6L, 5.4L)
Nov 18, 2017 01:43 PM
Ray West
May 1, 2017 03:17 PM
bdavis2424
2004 - 2008 F150
Nov 24, 2012 11:50 AM
Batjac
Apr 15, 2008 03:32 PM
