Modular V10 (6.8l)
Black particles in oil
Old Nov 13, 2025 | 07:58 PM
Mykah knabe's Avatar
Mykah knabe
My v10 has 138k miles. Ive been noticing some tiny black particles in the oil recently. Im not sure how long those have been there as I usually dont take such a close look at the oil. I cant tell if its gritty or not as its super small. But it is hard and doesnt break apart when rubbed between fingers. Im worried its metal and the engine is on its last leg. What does everyone think?
Old Nov 13, 2025 | 08:23 PM
riderboy1961's Avatar
riderboy1961
That little black dot on your finger? How it the world did you find something that small in your oil, just curious?
#1 - I would not be concerned
#2 - if concerned and it was my engine, I might consider putting in a quart of MMO into the engine oil, run it about 25 miles, drain the oil, replace the oil and filter. MMO will clean build up/gunk from the inside of the block.
However, this could also clean inside the block so well that you could develope seal leaks or gasket leaks because the MMO could knock away all the gunk build up that is built up around the seals and gaskets
I am thinking that #1 is a good choice, but I am not an expert either.
Old Nov 13, 2025 | 08:31 PM
Mykah knabe
im not sure, i guess im just looking too closely lol. theres around 3 or 4 of them each dip. thanks for the reassurance!
Old Nov 13, 2025 | 10:25 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
How many miles on that oil?
How many miles do you usually go between oil changes?
How many miles have you owned the vehicle?
Old Nov 13, 2025 | 11:22 PM
Mykah knabe
Last changed around 1500 miles ago.
I change every 3k.
been in the family since bought brand new in 2005, with meticulous maintenance.
Old Nov 14, 2025 | 08:26 AM
Peter Brush's Avatar
Peter Brush
8th Gear
Oil particles
I change every 3k.
I would be more concerned about particle diameter and toughness. If it's hard and larger than 2 mm then I'd track down the source since it will damage the bearing surfaces.
Old Nov 14, 2025 | 10:03 AM
Mykah knabe
They are a bit hard, but are only around 1mm, maybe less.
Old Nov 14, 2025 | 11:03 PM
CathedralCub
FTE Community Team
Next oil change, cut your filter open and see if there is a lot of this in there.
What kind of oil do you use?
What make and model of oil filter do you use?
Old Nov 14, 2025 | 11:46 PM
Mykah knabe
Im running valvoline max life synthetic blend 5w-20 (was going to switch to 5w-30 but spaced it🤦‍♂️) and the motorcraft fl820s filter.
Old Nov 15, 2025 | 04:19 PM
charlie g's Avatar
charlie g
FTE Community Team
i would send out a oil sample , that would be playing very safe
Old Nov 17, 2025 | 07:39 PM
Mykah knabe
Ill go ahead and send out a sample then.
Old Nov 17, 2025 | 10:29 PM
CathedralCub
FTE Community Team
I'd change to 5W30, too! Opinions vary, but I can't imagine ever running 5W20 on anything like this, expecially after the early V-10 recalls back in the late `90s for main bearing failures. I know those were defects theoretically, but still.
Old Nov 25, 2025 | 10:55 AM
super 6.8's Avatar
super 6.8
No way that is a millimeter in diameter. Regardless you'd think the filter would pick that up.
Old Nov 26, 2025 | 01:45 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Next time you see the black particles use a clean magnet and see if they are metallic. If not they are probably just small pieces of carbon probably from the pistons, no problem for a high milage motor.
Denny
tammlyn
6.7L Power Stroke Diesel
Jun 24, 2024 03:56 PM
rockwind1
Jan 16, 2023 08:42 AM
SoCalAngler
May 25, 2019 10:48 PM
speakerfritz
6.4L Power Stroke Diesel
Nov 25, 2015 08:27 AM
puck1263
Dec 19, 2005 12:35 PM
