What other years of trans can I use
Old Oct 18, 2025 | 07:37 PM
junkyardjeff's Avatar
junkyardjeff
I have a 89 F 250 that has a E4OD that I had rebuilt with the needed upgrades and the shop messed it up and has been back two times and still the same so I am done dealing with that shop and looking to put a used trans back in it so what other years can I use.
Old Oct 18, 2025 | 10:01 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Up through 1994 with no modifications. If it is 1995 or newer you have to swap the solenoid body for a 1994 or older.
Make sure you get one from the same engine and same drive, i.e., 4x2 or 4x4.
Old Oct 19, 2025 | 09:40 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Also, if you have a diesel engine, then your torque converter has 4 studs. The '95+ diesel converters are 6 stud, so you'd use both your old pack and converter.
1989 was the first and worst year for the E4OD. Getting out of that or finding a specialists in E4OD internal hard parts, would be very wise.
Franko72
Jan 13, 2010 04:56 PM
huntinzombie
Oct 16, 2008 01:27 AM
joseywales76
Jan 24, 2007 01:27 AM
john2139
S. California Chapter
Nov 24, 2004 04:36 PM
