Offroad & 4x4
Warn bumper studs
Old Aug 9, 2025 | 01:57 PM
Junktownbill99's Avatar
Junktownbill99
Warn bumper studs
I'm in the process of repainting my bumper, and it takes down into a few pieces, it seems to be held together with some studs. Only problem is after however many years, they are buttery soft and a few are broken. I plan on drilling all the way through and replacing with bolts, but if there's a better alternative, I'm all ears.
The studs run hold the flat,
The studs hold the flat, "wings" on
Old Aug 10, 2025 | 06:17 AM
MBDiagMan's Avatar
MBDiagMan
Great bumper! Could it not be put back together with bolts and nuts? I think you're onto the best approach that way.
Old Aug 10, 2025 | 11:17 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Stainless steel hdwr and maybe use pan head bolts (like a carriage bolt), if you want the outer head part smooth. Just have to make a round hole square to hold the head while tightening.
Old Aug 10, 2025 | 12:38 PM
Junktownbill99
These are the studs in question, I can fatigue them with a pair of vice grips, or while simply removing the nut.
Old Aug 11, 2025 | 09:29 PM
MBDiagMan's Avatar
MBDiagMan
Grade 8 fine thread bolts and nuts would increase clamp strength when replacing the studs.
If you call Warn customer service they will give you a new Warn decal if you tell them know that you are restoring a vintage Warn product/. Have the size of the decal at hand when you call.
Old Aug 11, 2025 | 09:37 PM
Junktownbill99
Vintage, huh? Too bad some dumb little deer ran into the passenger side at 60 mph, it is dented, but oh well, it's a truck. I'll go grade 8 for the bolts, should be much better. Perhaps I could learn to weld and add some reinforcement for the sides?
Already bought a new 4" decal for it! I'll be painting it a low gloss black (+ a hardener that may add some shine) right now I'm working on getting most of the rust and paint off.
Old Aug 12, 2025 | 04:54 AM
MBDiagMan's Avatar
MBDiagMan
It’s gonna look great!
No offense meant. About everything I own including myself is classified vintage these days. I guess I’m joining in with the misuse of the term.
My oldest Granddaughter is getting married this weekend, so I’m buried busy for another week, then I hope to get the cable on its way.
Old Aug 12, 2025 | 12:04 PM
Junktownbill99
Absolutely none taken! I like old stuff (that performs it's function well), or using stuff until it can't be used.
I have a cheap 2021 (ancient, I know) phone, and you should see my muck boots, I'm almost through the sole.
Old Aug 14, 2025 | 04:39 PM
77&79F250's Avatar
77&79F250
Since we are on the subject of a Warn bumper, if some one wants to make their own here you go.
Or I know a guy that repops them, but in a HD version and his redesign is thoroughly tested.
Old Aug 21, 2025 | 04:58 PM
Junktownbill99
Update
Studs are drilled out, not perfect, but not bad for simple measuring and freehanding. Currently working on removing rust and paint, there's some pitting, but not too bad.
Rollin350
Oct 26, 2024 11:32 AM
Edgethis
16
Apr 1, 2020 12:01 AM
Jwennet
17
Sep 10, 2018 04:17 PM
Chad149
6.7L Power Stroke Diesel
Mar 1, 2013 10:28 PM
Breaker 1-9
May 29, 2012 12:48 PM
