Just how flat does the exhaust manifold mating surface need to be?!
Old Aug 6, 2025 | 07:34 PM
FordGP's Avatar
FordGP
I recently purchased another old (1999) expedition with 139k miles. The previous owner had the exhaust manifold changed at some point with Dorman pieces, but the cheap gasket used blew out about a year ago at the the front of the #1 port. The manifold isn’t too bad so I was consider reusing it but I checked the plane and it is not as flat as expected! A little concave (especially #4 cylinder). Does anyone know if this is normal??
thanks!
Old Aug 6, 2025 | 08:06 PM
FordGP's Avatar
FordGP
I think I’ll be replacing this manifold due to pitting, but still curious about the plane question if anyone knows.
Im a little concerned about pitting on the head also but I’m not about to take that off at this point.
I see a lesson here about not letting your manifold leak go on too long!
Old Aug 8, 2025 | 07:44 AM
alloro's Avatar
alloro
When I replace exhaust manifold gaskets, I put 2 sets back on each side, along with exhaust sealer sandwiched between them. The sealer takes up any potential gaps, and to date, no exhaust gasket I've done this to has ever leaked.
Old Aug 8, 2025 | 10:52 PM
FordGP's Avatar
FordGP
Im intrigued.. which gasket type do you use and which sealer?
I purchased a triple layer metal gasket set to use but I have my doubts with the head surface being less than flat and smooth.
Old Aug 8, 2025 | 11:31 PM
Johnny Paycheck's Avatar
Johnny Paycheck
If you’re having big doubts, that’s fair, but find an exhaust shop that can get those manis sanded flat for you. Problem solved.
Old Aug 9, 2025 | 07:55 AM
FordGP's Avatar
FordGP
That sounds like a solution for the manifold, good call.
Can someone give advise on the head surface condition and more gasket thoughts? Thanks.
Old Aug 9, 2025 | 09:02 AM
alloro's Avatar
alloro
You can always add the sealant directly to the heads if you think there will be gaps. For the gaskets, I use what is specified, nothing special.
Old Aug 15, 2025 | 08:41 AM
FordGP's Avatar
FordGP
It’s all back together and sounds like a good seal. I used the Mahle metal gasket set plus Hi Temp Copper RTV between the head and gasket, plus SS hardware. I’m really really hoping this holds “forever”
Old Aug 16, 2025 | 01:28 PM
Beechkid's Avatar
Beechkid
Short answer, it needs to be flat.. within a few thousands or less. Copper gaskets with sealant will work for a long while.
endobear
26
Nov 30, 2020 11:23 AM
F100supercrew
Aug 20, 2020 07:31 PM
zjohnson3
2009 - 2014 F150
Mar 16, 2016 02:01 PM
freeky1
Sep 19, 2002 01:21 PM
The Man
Exhaust Systems
Jun 17, 2002 09:03 PM
