04 Navigator. OBD NOT COMMUNICATING
Old Jun 30, 2025 | 04:01 AM
Jenn12's Avatar
Jenn12
3rd Gear
Running fine til it wasn’t. No crank/start. PRNDL No park assist error, tried to run code but it says no communication. obd is getting power but shows OL on multimeter. Disconnected/tested
PCM, cluster and ABS, result is still OL. Triple checked fuses/relays, all good.
Chasing wire now. If anyone has any advice/suggestions please send my way.
Old Jun 30, 2025 | 05:11 AM
alloro's Avatar
alloro
The OBD connector power is shared with the 12v lighter circuit. So, if that fuse (#41) is good, you could be looking at an issue with the central junction box itself. See the image below.
Old Jun 30, 2025 | 11:15 AM
Jenn12's Avatar
Jenn12
3rd Gear
Thanks.
Going out to check fuses again.
Old Jun 30, 2025 | 12:33 PM
Jenn12's Avatar
Jenn12
3rd Gear
Rodents
Removed a panel and found that a rodent has been at work. So many wires to check. If anyone has any advice on narrowing down how to pinpoint it’d be welcomed.
Old Jul 1, 2025 | 06:45 AM
alloro's Avatar
alloro
There is no shortcut, you just have to take the time and inspect all that you can.
TreeGuy1982
Sep 7, 2023 08:12 PM
jayjaneda
Nov 3, 2012 11:44 AM
TJK1
Oct 18, 2011 02:55 PM
Spectramac
Apr 9, 2011 01:23 AM
