quick ficm question
Old Oct 18, 2011 | 12:59 PM
TJK1's Avatar
TJK1
quick ficm question
I have an 04 f250 with the 4 screw ficm, found a seven screw ficm from an 04 excursion. Can I just plug the seven screw ficm in or will it Need to be reflashed since mine has 4 screws
Thanks
Old Oct 18, 2011 | 01:08 PM
Rusty Axlerod's Avatar
Rusty Axlerod
No flash required to start/run the truck. It is possible to get a code for incorrect software version but truck will run. Just a roll of the dice as to which versions are in truck/FICM.
Old Oct 18, 2011 | 02:50 PM
TJK1's Avatar
TJK1
So if it is a different version I will get a code that will let me know I need it reflashed
Old Oct 18, 2011 | 02:55 PM
npccpartsman's Avatar
npccpartsman
The code will be a U0306 software incompatability code which just means that the FICM wasn't flashed with the PCM. If the truck runs good it's not a concern.
olyellow
Feb 4, 2019 06:22 PM
1950t
Aug 5, 2011 08:55 PM
gmckay
Sep 19, 2007 02:23 PM
