Lowing a 03 Explorer.
Old Jun 26, 2025 | 06:59 PM
Richard A. Coyle's Avatar
Richard A. Coyle
4wd Low
OK I swapped in a set of lowing springs and it dropped down nicely, but ride a bit harder...and when we pulled out the broken front Dif and junk she lifted a inch or two and now the front is about 2 inches higher.
Seems there is a lot if dead space with the 5 inch rod below the shock to the lower arm which could be shorter.
So are some shorter struts I can use.
The real looks like the there is NO room any where and the coil spring has very little coil run for any travel, in fact i would like to life the rear about an inch.
So lower the front bu 2 inches.
Rich
Gwilkrrs
Jun 27, 2025 05:35 AM
CraigerF100
38
Oct 6, 2021 09:40 AM
exp_bill
Jun 15, 2005 11:42 PM
fourwheelnford
Jun 13, 2005 11:22 AM
mnm1997
1978 - 1996 Big Bronco
Dec 28, 2000 06:18 PM
