Ok- ‘02 v8 Explorer. Under braking my son said peddle went to the floor-
no fluid in master cylinder and wet on frame and suspension right in front of rear passenger wheel.
it is pouring so I didn’t spend much time
it looks like the line is hiding above something and not really accessible
someone have a diagram or thought?
I wanted to just clamp the line of and fill the reservoir to get the truck home————
Is there a junction before the tank I can take apart and run a new line below the tank?
I retrieved the vehicle on a trailer and plan to look at repairing tomorrow
line comes down the driver side rail then crosses over to the passenger side at the rear.
the metal crossover line had a bad spot right above the tank where it bends around the fuel lines. not a hard fix just tedious....
new crossover line installed.
