Ball Joint Replacement 1999 Mercury Mountaineer AWD
Old Mar 8, 2025 | 06:20 PM
tnfordblue's Avatar
tnfordblue
Felt some abnormal movement in the front end of my '99 Mercury Mountaineer while driving home about a week ago. It's had a lot of squeaking going on ever since I got it and could tell the factory ball joints were dry. I jacked it up and could see the control arm move quite a bit before the spindle started to move, and the opposite when setting back down. Ordered a pair of MOOG lower ball joints and a ball joint press. Tool got here yesterday so I dove into it today. Didn't even get started and didn't have a socket to fit axle nut, but AutoZone did. 1 1/4" deep well $14 plus 25 mile round trip. Got everything broken down to use the press and pushed the old joint out. When I took the spindle loose, I discovered the uppers were extremely worn too. So I'm ordering MOOG upper control arms from Rock Auto. I've been toting around a split boot for the left outer CV axle, and going to put it on while it's staring me in the face. To be cont...
Old Mar 9, 2025 | 05:00 PM
Alex from GA's Avatar
Alex from GA
My buddy and I did my '99 Explorer AWD a few years ago. Have to have a good alignment guy when you're done changing them.
Old Mar 9, 2025 | 05:32 PM
tnfordblue's Avatar
tnfordblue
I figured that on alignment, especially the way the right upper arm is designed. I was also told by a fellow Explorer/Mountaineer owner to have it at ride height when tightening upper control arms at frame.
Old Mar 17, 2025 | 02:30 PM
aquanaut20's Avatar
aquanaut20
Ride height means with the vehicle loading the suspension..
Old Mar 19, 2025 | 05:59 AM
tnfordblue's Avatar
tnfordblue
Stormy weather this weekend slowed down my progress, but I have managed to get the left lower ball joint pressed in, and the nuts off the upper control arm bolts. Ran out of daylight yesterday trying to get the bolts out. Hitting fuel or brake lines and got to get a better look before I just start prying things out of the way.
Johndg1991
Dec 22, 2022 01:21 PM
sunbelt57
Aug 11, 2020 04:43 AM
DustMan24
Mar 10, 2019 03:10 PM
bullnose1985
21
May 21, 2017 08:20 PM
Snow Descent
1997 - 2003 F150
Jul 9, 2014 08:54 AM
